sergt3 8 #1 Posted July 23, 2019 don't know what the difference is but which do you guys prefer a side discharge or rear discharge..im sure there is a reason they made both.... Share this post Link to post Share on other sites
ebinmaine 77,534 #2 Posted July 23, 2019 We don't even use any of our wheel horses to mow. We have nearly no lawn. I use an older snapper push mower. that said, I'm curious to see what everybody else is going to say so I'm going to follow along.... 1 Share this post Link to post Share on other sites
adsm08 4,213 #3 Posted July 23, 2019 A side discharge deck shooting the clippings out the side of the deck, usually leaving them in a distinct line of clippings along the path the mower followed. A rear discharge deck has the rear open and blows the clippings out the back, usually leaving a nice even layer of clippings where ever it goes. I have found that I prefer a rear discharge deck. I don't have or mess with baggers, and I don't like the lines of clippings that get left in the yard from a side discharge deck, I do like the even and cleaner look a rear discharge deck leaves. The big downsides to an RD deck are that you can't hook a bagger to it, and if you hit something big, like a rock or a chunk of cinder block or something, it can be thrown out the rear of the deck and damage the axle. But you also don't get clippings blown back in your face if you mow while it is windy. Share this post Link to post Share on other sites
The Tuul Crib 7,347 #4 Posted July 23, 2019 I like both. The side discharge i great for me when it comes time to round up leaves. The rear discharge makes the lawn look more even. to 1 Share this post Link to post Share on other sites
pfrederi 19,955 #5 Posted July 23, 2019 My rear discharge leaves two windrows one on each side not evenly spread. 1 1 Share this post Link to post Share on other sites
adsm08 4,213 #6 Posted July 23, 2019 4 minutes ago, pfrederi said: My rear discharge leaves two windrows one on each side not evenly spread. What size is it, and is the middle blocked off? I have an RM-327 which is about the smallest deck WH ever used, and it is open the whole way along the back, and leaves a single even trail. Share this post Link to post Share on other sites
ol550 847 #7 Posted July 23, 2019 11 minutes ago, pfrederi said: My rear discharge leaves two windrows one on each side not evenly spread. Share this post Link to post Share on other sites
pfrederi 19,955 #8 Posted July 23, 2019 (edited) 26 minutes ago, adsm08 said: What size is it, and is the middle blocked off? I have an RM-327 which is about the smallest deck WH ever used, and it is open the whole way along the back, and leaves a single even trail. Rm-366 wide open across the back Edited July 23, 2019 by pfrederi Share this post Link to post Share on other sites
adsm08 4,213 #9 Posted July 24, 2019 22 minutes ago, pfrederi said: Rm-366 wide open across the back Might be because the blades are so far apart. That's bigger than mine. Share this post Link to post Share on other sites
midpack 1,105 #10 Posted July 24, 2019 I've tried every configuration except 60" SD. my favorite this year... I thought was going to be the 42" RD I got last fall. But having hooked up the 48" SD makes me think twice. Great cut and I can really fly when mowing! Only drawback is my tow behind sweeper doesnt work that well with it. Sooo... to answer the OP.... whatever one is mounted and has gas in the tractor! (Those big bores can be thirsty) 2 1 Share this post Link to post Share on other sites
troutbum70 858 #11 Posted July 24, 2019 I can't speak for other makes of tractors, I bought my WH 417 new with a rear discharge and I hated it for 20 years. So when I had it wore out I bought a brand new 42 inch side discharge deck for the 417 and I will never go back to a rear discharge. The only thing a rear discharge has to offer for me is the ability to mow in either direction to avoid going in a circle. No matter how I adjusted the RD it always wind rowed the grass behind the tractor and because of the layout of my property and obstacle's pulling a sweeper was not an option. So your question brings on a lot of opinions and probably makes it difficult for you to decide which to go with. Good luck Share this post Link to post Share on other sites
Darb1964 1,151 #12 Posted July 24, 2019 I like the rear because you can cut close on both sides,saves time. I used one for many years. I have for the last few years use a side with a bagger and feed the clipping to my wife's chickens,goats,geese,and turkeys. Side is nice for leaves in the fall also. I never worried much about the wind rows. 1 Share this post Link to post Share on other sites
roadapples 6,987 #13 Posted July 24, 2019 Don't like the way a RD packs the grass on the left rear wheel... 3 Share this post Link to post Share on other sites
midpack 1,105 #14 Posted July 24, 2019 6 hours ago, roadapples said: Don't like the way a RD packs the grass on the left rear wheel... I noticed the hydro cooling fan doing that, no prob with an 8 speed. I did make sure to clear that after every mow Share this post Link to post Share on other sites
Pullstart 68,980 #15 Posted July 24, 2019 I have only ever used an RD on a WH. The cut is nice, if I move slow on full rpm’s. The clippings always seemed to center in the middle of the cut, leaving horrendous stripes in the yard. Maybe if I cut more often, that wouldn’t be the case... but once a week is my max. On my 32” deck that came with Putt Putt, currently on The Polished Turd, I closed off the front with an 1/8” plate. It kept the clippings away from the engine, but the transmission and inside the rear wheels was always coated. When I upgraded to the C-101 with a 42” RD, the clippings never bothered the engine as much, but covered from the shifter to the hitch, always creating a huge mess. Now, I cut with a 52” SD Scag Freedom Z zero turn and love how the clippings scatter about in the yard. I can still hook the sweeper up during the rainy season when grass seems to grow inches per day and make passes with a WH when I’m finished mowing. Chickens sure love all the clippings coming to them in the spring and early summer! Recently I picked up that GT-1600 with a 42” SD and I’m itching to get some practice seat time on that one, just for comparison to other mowers I’ve run. Share this post Link to post Share on other sites
lynnmor 8,644 #16 Posted July 24, 2019 I have a 42" RD that is wide open, the windrow is to the right and is a real problem. I no longer use it except for fall cleanup while pulling a sweeper. Until this season, I used a 60" deck and it performed well. In order to take the load off the horses, I bought a 60" zero turn this year. Share this post Link to post Share on other sites
edgro 680 #17 Posted July 24, 2019 I have been mowing with a SD, then use RD with sweeper for cleanup if needed Share this post Link to post Share on other sites
Tonyp 285 #18 Posted July 27, 2019 I use both a different times. I have 3 machines, two have decks , one a rear and one a side. When there is a lot of "stuff" on the lawn I use the side discharge to corral the STUFF. Always blowing and cutting in the same direction. My wife uses a 315-8 with a rear discharge, she loves it, she goes over and over the clippings ! I think its some kind of therapy for her ! Share this post Link to post Share on other sites
ronhatch 410 #19 Posted July 27, 2019 3 years ago I bought a 1979 C 101 with a RD 36" deck. I restored the tractor (what a mess underneath it due to the deck) and traded a guy even up, believe it or not, for a older 42" SD deck. I wasn't happy with the way it threw a third of clippings out the front and didn't do a good job of spreading them evenly out the side either. So, I installed a stainless steel baffle that followed the front curve of the deck BUT extended down about 1" lower then the deck and it also had a small inward curving lip. What a difference! No clippings blowing out the front, instead they all blew out the side in a more forceful and evenly spread stream. By replacing the deck wheels with boat trailer rollers, I can't tell the difference between mowing with my WH or my B-10 AC (Simplicity). They both make my lawn look like a ball park. 1 Share this post Link to post Share on other sites
roadapples 6,987 #20 Posted July 27, 2019 4 hours ago, Tonyp said: 4 hours ago, Tonyp said: My wife uses a 315-8 with a rear discharge, she loves it, she goes over and over the clippings ! I think its some kind of therapy for her ! Seat time..... Share this post Link to post Share on other sites
AHS 1,597 #21 Posted July 27, 2019 I’ve always been a fan a the RD. First on a C101 with a 36” now with a different one, a 14hp with a 42”. They always work good.keep the blades sharp and you’ll have no problem. Share this post Link to post Share on other sites
