sergt3 8 #1 Posted July 21, 2019 I need to know if a 42 inch rear discharge deck will mount and work on on a tractor with a 42 inch side discharge Share this post Link to post Share on other sites
Racinbob 12,812 #2 Posted July 21, 2019 Pretty much all decks for the B series thru 1977, all C's, 300's, 400's and 500's will interchange. We could use a bit more info to give a certain answer. Share this post Link to post Share on other sites
midpack 1,105 #3 Posted July 21, 2019 If its attach a matic it should. You'd need a different belt 2 Share this post Link to post Share on other sites
sergt3 8 #4 Posted July 21, 2019 the 42 rear discharge is coming off what looks like a 10 horse b model 8speed..going on a c120 automatic side discharge and they are both attach-a-matics . 1 Share this post Link to post Share on other sites
608KEB 812 #5 Posted July 21, 2019 That will work. Off subject, but a 42" side discharge will not work on a 520H. The deck wheels will hit the rear tractor tires. You would have to widen the bracket that the deck wheel is attached to. 1 Share this post Link to post Share on other sites
