TimC121 0 #1 Posted July 12, 2019 when you hook a tiller assist spring to the tractor where to hook the spring? I have the flat axle brackets should I look for a axle bracket made from angle iron that has extra hole for the spring? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,511 #2 Posted July 14, 2019 You could but may be easy for you to make one. Use angle with the same dimensions as the flat bar but longer. I do not have one to know the original length. Still available from Toro but a bit rich. Item #33. https://www.partstree.com/parts/toro/accessories/97-36tl01-toro-36-tiller-1979/tiller-36-in-92-cm-vehicle-identification-number-97-36tl01_2/ Garry Share this post Link to post Share on other sites
