dalez 148 #1 Posted July 9, 2019 I recently purchased a 97 416-H and am going through it. The dipstick looks short and I don't want to overfill it. I've attached a photo of it for reference if someone could confirm it is the correct on I would sure appreciate it. Thanks, Dale Share this post Link to post Share on other sites
ZXT 2,402 #2 Posted July 10, 2019 4 hours ago, dalez said: I recently purchased a 97 416-H and am going through it. The dipstick looks short and I don't want to overfill it. I've attached a photo of it for reference if someone could confirm it is the correct on I would sure appreciate it. Thanks, Dale Can't help you on the length that it should be since I don't own a tractor of that series, but I assume it's still showing to be low after you put oil in it. If it still has old oil in it, you could drain it and compare what came out (and where it lay on the dipstick) to what the factory says should be in it. It will obviously be less than it should due to the residual in the transmission and what was in the filter, but it would give you an idea. Share this post Link to post Share on other sites
dalez 148 #3 Posted July 10, 2019 I thought of that but still would like to know about the dipstick. It only goes into the tranny about an inch after the dipstick tube. It just seems it would be filled almost to the brim. Thanks. Share this post Link to post Share on other sites
pfrederi 20,670 #4 Posted July 10, 2019 Hydros are filled almost to the brim.... Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #5 Posted July 10, 2019 16 hours ago, dalez said: I recently purchased a 97 416-H and am going through it. The dipstick looks short and I don't want to overfill it. I've attached a photo of it for reference if someone could confirm it is the correct on I would sure appreciate it. Thanks, Dale That looks close to the one on my 520 with Eaton 1100 rear. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,276 #6 Posted July 10, 2019 Part number on the stick ? 110768-03 https://www.partstree.com/parts/toro/parts/110768-03/ Garry Share this post Link to post Share on other sites
dalez 148 #7 Posted July 10, 2019 2 hours ago, gwest_ca said: Part number on the stick ? 110768-03 https://www.partstree.com/parts/toro/parts/110768-03/ Garry No part #. It just says to "Check oil with engine off" Except for length it is very much the same as the one on my 310-8 which has a part # I will go with pfrederi about it being almost filled to the brim and just assume it is the correct one. Thanks all. Share this post Link to post Share on other sites
dodge78 102 #8 Posted July 11, 2019 Looks the same as my 418 dip stick Full mark about where yours shows 8 inch mark 1 Share this post Link to post Share on other sites
dalez 148 #9 Posted July 17, 2019 On 7/11/2019 at 2:17 PM, dodge78 said: Looks the same as my 418 dip stick Full mark about where yours shows 8 inch mark That's good to know. No guessing if it is correct. Thanks Share this post Link to post Share on other sites
cleat 8,986 #10 Posted July 17, 2019 And just so you know, the dipstick handle is also the transmission vent. Make sure it is clear and that you can blow through it. A couple of mine were plugged and that can cause a seal to leak due to pressure buildup. 2 1 Share this post Link to post Share on other sites
