M. Weiner
Low Max RPM ~3000
M. Weiner
Im having some issues with a fresh rebuild K181 which doesnt want to run full speed.
I first noticed it was running slowly as my ground speed felt slower than expected. To confirm I ordered a cheapo RPM/Hour display which reads spark and knows it sparks once per 2 revolutions.
Typical Max it is running around 2800-3200 RPM. Idle is okay at ~1200 RPM.
How can I increase this to the rated 3600 RPM?
pfrederi
M. Weiner
In the lower left image where is the nub on the speed control disc?
I have tried a number of settings with the governor with no change. The throttle bracket is currently near a 7 o' clock position.
M. Weiner
Update: I adjusted the throttle bracket to the 6 o' clock position with no change.
Further anticlockwise rotation is not possible without re-routing the cable around the points cover.
