seven 202 #1 Posted July 8, 2019 Has anyone tried converter from the pull twist style to lever style I would much appreciate your help ? Share this post Link to post Share on other sites
daveoman1966 3,841 #2 Posted July 8, 2019 I did... a few years back, but forget what tractor I was working on. In any case, I have both the throttle and choke cable for you to work with. You gotta know that you'll need to trim the length of the cable, depending on your application. What tractor are you working with??? Share this post Link to post Share on other sites
daveoman1966 3,841 #4 Posted July 8, 2019 (edited) You'll need : 1) Slotted dash panel and metal backing plate. 2) Choke and Throttle Cables...trim to length. 3) Push-on slotted knobs for Choke & Throttle. 4)couple of stand-off clamps for the cables. I can get you ALL of this...50 bux & 7 to sjip in USA. NOTE... I don't have pic of the THROTTLE cable, but it is the exact same style as this CHOKE cable (left side) ./.. but in reverse for the dash mounting on the opposite side (right side). Edited July 8, 2019 by daveoman1966 Share this post Link to post Share on other sites
