Tribsa500 6 #1 Posted July 7, 2019 Hi folks, my '74 K301 starts and runs o.k; however when i stop it,gas runs out of the Walbro carb mouth,any ideas.I've cleaned the fuel bowl and sprayed 'carb cleaner' as best as possible. With the ignition (and therefore the fuel pump) off,how is that happening? Is it a syphoning effect? Share this post Link to post Share on other sites
ebinmaine 75,842 #2 Posted July 7, 2019 Carb needle is stuck open. Remove the carburetor and give it a good cleaning. Also replace or carefully clean the needle and seat. 3 Share this post Link to post Share on other sites
Tribsa500 6 #4 Posted July 7, 2019 Hi, I thought it might be something like that,but I wondered if there was a 'crafty' fix,because this carb has not been of for decades,so I'll have to get a full gasket/seal kit. Wow,you guys rise early on a Sunday morning! Many thanks. 2 Share this post Link to post Share on other sites
ebinmaine 75,842 #5 Posted July 7, 2019 On an old Kohler a full carb kit isn't but a few things. One thing you could try is to remove the bowl with the carb still on the engine. You can likely buy the needle separately. If it's the type with a rubber end you might get away with just replacing the needle. Share this post Link to post Share on other sites
JCM 10,415 #6 Posted July 7, 2019 Craig, you wouldn't happen to have Taryls dentist phone # by chance do you, I think I need to upgrade, all kidding aside great info. Thanks 3 Share this post Link to post Share on other sites
JCM 10,415 #7 Posted July 7, 2019 I think this Forum is more addicting than the tractors, I need to get off this damn forum and get those trails ready for 9-7-19 2 Share this post Link to post Share on other sites
wfrpalm 218 #8 Posted July 7, 2019 1 hour ago, ebinmaine said: Carb needle is stuck open. Remove the carburetor and give it a good cleaning. Also replace or carefully clean the needle and seat. This! 1 Share this post Link to post Share on other sites
Tribsa500 6 #9 Posted July 7, 2019 Thanks folks, I had to remove carb (the replacement muffler is to close to it) and when I removed float I found what looked like a dog hair trapped down along side the needle.Job done.Also fitted an inline filter and new pipes (ethanol.......don't we just love it ?!!!!) Cheers Guys. 3 Share this post Link to post Share on other sites
