redone 45 #1 Posted July 3, 2019 Hi all. I am searching for valve cutting tool. 45 degree 30 degree cutters with all guides. Thanks Bill Share this post Link to post Share on other sites
WHX?? 54,528 #2 Posted July 3, 2019 Did you check good old jungle site or fleabay Bill? I been eyeballing some cheapy sets those places that might be good enough for a hobbyist. https://www.amazon.com/CARBIDE-VALVE-CUTTER-VINTAGE-BIKES/dp/B071WW28KN/ref=sr_1_7?crid=1YASCMGOHP1DG&keywords=valve+cutting+tool&qid=1562188232&s=gateway&sprefix=valve+cutting+tool%2Caps%2C169&sr=8-7 2 Share this post Link to post Share on other sites
lynnmor 8,556 #3 Posted July 3, 2019 I use the Neway tools, expensive but they do a good job. Most likely you will need to add additional tooling to a kit for your specific job. I have learned that these tools will cut well if you replace the cutting inserts regularly and turn the cutters rather slow. If you cut too fast, chatter will start and that is difficult to remove once it is there. One Source Share this post Link to post Share on other sites
richmondred01 2,333 #4 Posted July 6, 2019 (edited) Neway is the way to go. However, unless you are regularly cutting seats, a good machine shop will typically charge 40-50 bucks to resurface the valves and grind the seats. Just my 2 cents. Edited July 6, 2019 by richmondred01 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #5 Posted July 7, 2019 Got a complete valve machine in the F.I.L's garage... May be coming up for sale shortly... Maybe I'll get some pics tomorrow. 1 Share this post Link to post Share on other sites
