WildmanC120 613 #1 Posted July 3, 2019 Are these WH wheel weights? Picked them up tonight on FB marketplace cheap. I guess it doesn't really matter the brand was just curious. 1 Share this post Link to post Share on other sites
RandyLittrell 3,903 #2 Posted July 3, 2019 Ya did good!! Those are wheelhorse weights! Randy 1 Share this post Link to post Share on other sites
oliver2-44 10,679 #3 Posted July 3, 2019 Looks like you need to set up an E-Tank to clean them up the easy way! 2 Share this post Link to post Share on other sites
WildmanC120 613 #4 Posted July 3, 2019 Nice. I thought they were WH weights. I did well @ $50 for the pair. Not looking forward to clean up and paint though. 2 Share this post Link to post Share on other sites
ericj 1,579 #5 Posted July 3, 2019 I bought a set last year that the guy had painted Yellow. I used a wire brush on a 4 1/2 grinder and cleaned them up and painted them black eric j 1 Share this post Link to post Share on other sites
Chris T 361 #6 Posted July 3, 2019 57 minutes ago, WildmanC120 said: Are these WH wheel weights? Picked them up tonight on FB marketplace cheap. I guess it doesn't really matter the brand was just curious. You stole them for that price!! Good find 👍🏻 1 Share this post Link to post Share on other sites
squonk 43,720 #7 Posted July 3, 2019 While those weights are what WH sold, several brands of tractors used those weights from their factory. Share this post Link to post Share on other sites
lynnmor 7,789 #8 Posted July 3, 2019 11 hours ago, WildmanC120 said: Nice. I thought they were WH weights. I did well @ $50 for the pair. Not looking forward to clean up and paint though. Get them sandblasted, no way would I spend hours to do them and still have a poor job. 1 Share this post Link to post Share on other sites
Pullstart 66,604 #9 Posted July 3, 2019 E-tank is about as easy as it gets for stripping paint and rust.... 1 Share this post Link to post Share on other sites
WildmanC120 613 #10 Posted July 3, 2019 31 minutes ago, pullstart said: E-tank is about as easy as it gets for stripping paint and rust.... How would I set that up? Share this post Link to post Share on other sites
The Tuul Crib 7,339 #11 Posted July 3, 2019 I would do electrolysis.Easy and affective! Share this post Link to post Share on other sites
The Tuul Crib 7,339 #12 Posted July 3, 2019 Find a good old 12 V battery charger that doesn’t shut off that is constant. The water solution should be washing soda mixed in with the water and plug it in again don’t let the piece to be cleaned touch the sacrificial metal . I hope this makes sense Share this post Link to post Share on other sites
roadapples 6,983 #13 Posted July 3, 2019 Check Utube videos... Share this post Link to post Share on other sites
Pullstart 66,604 #14 Posted July 3, 2019 1 hour ago, WildmanC120 said: How would I set that up? Here is my tub. It’s a 55 gallon drum cut in half, with some scrap strapping and a brake rotor welded together for the anode. I suspend my parts with wire, wood, metal rod.... whatever keeps the anode and part from touching. I found that my 24v setting on my charger works much quicker (twice as fast?) as the 12v setting! 2 Share this post Link to post Share on other sites
Pullstart 66,604 #15 Posted July 3, 2019 Also, the anode should be arranged in a manner that is in a direct path of the part to be cleaned. Multiple anodes around the edges of the tub and one or two across the bottom would work great! Share this post Link to post Share on other sites
The Tuul Crib 7,339 #16 Posted July 3, 2019 28 minutes ago, pullstart said: Here is my tub. It’s a 55 gallon drum cut in half, with some scrap strapping and a brake rotor welded together for the anode. I suspend my parts with wire, wood, metal rod.... whatever keeps the anode and part from touching. I found that my 24v setting on my charger works much quicker (twice as fast?) as the 12v setting! Mmm is it soup yet??? 2 Share this post Link to post Share on other sites
857 horse 2,588 #17 Posted July 3, 2019 AMAZING RESULTS,,,,,,,,LET THE MAGIC BEGIN !!!!!!!!!!!!!!!!!! 1 1 Share this post Link to post Share on other sites
SPINJIM 1,986 #18 Posted July 3, 2019 Do you just use a standard 10 amp battery charger, like the one I use on my car and tractor batteries, or do you need an industrial charger? Jim Share this post Link to post Share on other sites
pfrederi 18,633 #19 Posted July 3, 2019 old simple is better no need for heavy duty. The new fancy chargers want to see some battery voltage before they will start charging. I use a Wards Riverside wonder how old it is.... 1 Share this post Link to post Share on other sites
RandyLittrell 3,903 #20 Posted July 3, 2019 12 hours ago, squonk said: While those weights are what WH sold, several brands of tractors used those weights from their factory. Thanks, I did not know that! Randy Share this post Link to post Share on other sites
The Tuul Crib 7,339 #21 Posted July 3, 2019 3 hours ago, pfrederi said: old simple is better no need for heavy duty. The new fancy chargers want to see some battery voltage before they will start charging. I use a Wards Riverside wonder how old it is.... Wow now thats an antique!! But will out last anything on the shelf today! Heres what l use 1 Share this post Link to post Share on other sites
