cafoose 3,528 #1 Posted July 2, 2019 I was wondering where the side oil plug is on a 7-1251 tiller? I was reading the manual and it says fill with 90 weight until it comes out the side plug. I can't find the side plug. . Where is the drain plug? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,909 #2 Posted July 2, 2019 I read where it is on the bottom of the case. It is the same size 1/2" npt plug as the top one. I can see how the left and right casings may be identical so look on the bottom of the right casting opposite the top plug. Garry 1 Share this post Link to post Share on other sites
cafoose 3,528 #3 Posted July 2, 2019 3 hours ago, gwest_ca said: I read where it is on the bottom of the case. It is the same size 1/2" npt plug as the top one. I can see how the left and right casings may be identical so look on the bottom of the right casting opposite the top plug. Garry Sounds like that may be where the drain is but I thought there should be a plug on the side that you fill from the top plug until it comes out the side plug. Share this post Link to post Share on other sites
