Wildhorse 303 #1 Posted June 30, 2019 What is the best throttle position to engage and disengage electric clutch to prevent wear or damage? Share this post Link to post Share on other sites
pfrederi 19,893 #2 Posted June 30, 2019 I try to engage mine at idle. They are sort of abrupt. The only one i use is on a C175 with a sweepster and only because the engine is a transplant forma a JD317 and has not thrust bearings. Share this post Link to post Share on other sites
Wildhorse 303 #3 Posted July 1, 2019 49 minutes ago, pfrederi said: I try to engage mine at idle. They are sort of abrupt. The only one i use is on a C175 with a sweepster and only because the engine is a transplant forma a JD317 and has not thrust bearings. Thank you! Share this post Link to post Share on other sites
shallowwatersailor 3,220 #4 Posted July 1, 2019 The owners manual for the 5xi series that used electric clutches exclusively stated to engage at full rpm. Share this post Link to post Share on other sites
