953 nut 69,481 #26 Posted June 3, 2022 2 hours ago, Cookie said: Which belt did you replace ? I have had good results with the Kevlar Belts from Tractor Supply. Your drive belt is Wheel Horse part # 7473 which is a 5L-820, 5/8" wide 82" long belt. Tell us about yourself and your Wheel Horses. You can do an introduction at this link. https://www.wheelhorseforum.com/forum/47-introductions/ 1 Share this post Link to post Share on other sites
peter lena 10,076 #27 Posted June 3, 2022 @Sparky would go with just the spring , would also detail lubricate all related linkage / movement points , might even be a time to get a idler pulley with a bigger bearing , like a local bearing distributor , bigger wide rubber side shields , do a hi temp grease change , might have to bronze bushing larger bearing to 3/8 " for perfect refit , done that . no noise or failures , greasy pete Share this post Link to post Share on other sites
Cookie 0 #28 Posted June 9, 2022 I replaced the drive belt and removed the little shock and it wasn't working like it was supposed to. My clutch pedal stopped "chattering" but when I went to put it in 3rd the tractor stood up on it's hind wheels. If I was to put a spring where the little shock was would it prevent the front end of the tractor from going up in the air or should I replace the spring at the end of the clutch rod, would that stop the front end from coming up ? Share this post Link to post Share on other sites
peter lena 10,076 #29 Posted June 9, 2022 (edited) @Cookie sounds like a combination of , lack of lubrication rusty linkage areas. never do wheelies , if your linkage is smooth in function , its always smooth . that clutch rod spring might need replacing , typically that small shock was indented to temper engagement . have an aerosol lubricant with the extension tube ? grease fitting on the clutch pedal ? would go after every related linkage point , with lube and verify as you go , for ease of function . regularly go over that entire set up for ease of movement . you could also have an idler pulley thats binding up , giving you that jump . drive line pictures on this site , to show you what's involved , pete. Edited June 9, 2022 by peter lena 1 Share this post Link to post Share on other sites
Lagersolut 802 #30 Posted June 9, 2022 My 315-8 and another tractor I restored and sold had the damper replaced with the old school spring - the damper bottomed out on my 315 - when I removed it and went the spring route got a lot more use out of the old belt . I think for those of us that know how to work on these machines it's personal preference - I prefer the spring - breaking in a new belt you can do wheelies easy if you're not careful ad get used to it and broke in . My vote lose the damper . 1 Share this post Link to post Share on other sites
Cookie 0 #31 Posted June 10, 2022 Lagersolut, would you happen to have the spring number of that spring you used ? Share this post Link to post Share on other sites
Lagersolut 802 #32 Posted June 10, 2022 2 hours ago, Cookie said: Lagersolut, would you happen to have the spring number of that spring you used ? Toro 108035 Share this post Link to post Share on other sites
