seven 202 #1 Posted June 30, 2019 I have a few old carberaters laying around that probably would be fine if I was to replace the bushings I've read that all you need to do is pick em up at Ace is there a certain standard size on these or should I just take one with me and look Share this post Link to post Share on other sites
tunahead72 2,662 #2 Posted June 30, 2019 Hillman #58087, 1/4" i.d. x 7/16" o.d. x 1/16" thick bronze thrust bushing, you'll probably have to stack two together on each carb to give you the 1/8" thickness you need. 1 1 Share this post Link to post Share on other sites
pfrederi 21,190 #3 Posted June 30, 2019 If you need alot 3 Share this post Link to post Share on other sites
