CHARGER9AUTO 3 #1 Posted April 9, 2009 I aquired another tractor today made only one year 1973 10 AUTOMATIC . how do you Get the Valve - By Pass loose It does not turn . Ben :omg: Share this post Link to post Share on other sites
wh500special 2,338 #2 Posted April 9, 2009 Ben, I had a 16-Auto that I never was able to free up the bypass valve. For that tractor I just put the rear end on a dolly and pushed it around that way. And I always made sure I parked it strategically so that it didn' block anything I needed in case I couldn't start it. But I have had a few other tractors where an impact driver (the kind that looks like a screwdriver and you hit it with a hammer) was enough to free it up. You can also try visegrips, but since the screw is pretty hard - and in a tight spot - they can be tough to use too. Whatever you do, don't get too carried away because if you snap that sucker off you're going to have a bigger project on your hands. Good luck on your new toy. Steve Share this post Link to post Share on other sites
CHARGER9AUTO 3 #3 Posted April 9, 2009 Ben, I had a 16-Auto that I never was able to free up the bypass valve. For that tractor I just put the rear end on a dolly and pushed it around that way. And I always made sure I parked it strategically so that it didn' block anything I needed in case I couldn't start it. But I have had a few other tractors where an impact driver (the kind that looks like a screwdriver and you hit it with a hammer) was enough to free it up. You can also try visegrips, but since the screw is pretty hard - and in a tight spot - they can be tough to use too. Whatever you do, don't get too carried away because if you snap that sucker off you're going to have a bigger project on your hands. Good luck on your new toy. Steve Steve, The problem is fixed the By Pass Valve is free with some PB solvent , Vice Grips first then Screwdriver it finally turned . for all the replys . Ben Share this post Link to post Share on other sites
