NYJack 9 #1 Posted June 25, 2019 Here is question I need help with. On my hydro wheel horse when I turn the key I get nothing, not even a click out of the solenoid. Some times the little light is on about the drive switch but not always. If I jump across the two poles of the solenoid it starts right up. That is not fun as sparks fly and I need my adult kids, non mechanical, to mow the lawn.... So, do you think it is the solenoid or one of the many safety switches? Thank You! Share this post Link to post Share on other sites
953 nut 66,085 #2 Posted June 25, 2019 The wiring on various years and models has changed over the years. Can you be a little more specific? The problem is probably a corroded connection in the wiring to the safety switches. It you take a small jumper from the battery "+" to the small wire on the solenoid will it crank over? If it will then the solenoid is fine. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #3 Posted June 25, 2019 I would check all electrical connections and could possibly be the switch. Share this post Link to post Share on other sites
Razorback 1,319 #4 Posted June 25, 2019 I vote for safety switch somewhere. 1 Share this post Link to post Share on other sites
NYJack 9 #5 Posted June 25, 2019 Sorry, it is 312 Hdryo with the 12 HP Koehler. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,234 #6 Posted June 25, 2019 35 minutes ago, NYJack said: Sorry, it is 312 Hdryo with the 12 HP Koehler. Still not enough to identify. By chance do you have the model number and serial number from the decal on the rear fender pan under the left side of the seat? Failing that post all the numbers off the engine decal including the serial number. Garry 1 Share this post Link to post Share on other sites
953 nut 66,085 #8 Posted June 26, 2019 (edited) You have a 1991 312-H This manual has your wiring in it. Edited June 26, 2019 by 953 nut Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,234 #9 Posted June 26, 2019 I think 953 nut misread your model number. Your tractor is a 1992 model 51-12KE02. Might not make any difference but just in case it does ---- Garry Share this post Link to post Share on other sites
peter lena 9,885 #10 Posted June 26, 2019 dielectric grease and fresh wire helps out , pete 1 Share this post Link to post Share on other sites
