CCW 1,519 #1 Posted June 23, 2019 Does anyone know about these wheel weights. Case VAC rear wheel weights Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #2 Posted June 23, 2019 (edited) 3 hours ago, SPS said: Does anyone know about these wheel weights. Case VAC rear wheel weights Case VAC is an older real farm tractor with 28" rear wheels...those weights are bigger than the tires on the 312-8 ... The cast iron 12" weights are getting harder to find have you considered the sand/concrete filled plastic wheel weights that are more easily procured? Cub 12" or Cub Cadet weights are approximately 25# each are the most commonly found cast weights. Pictured below. Edited June 23, 2019 by WVHillbilly520H Share this post Link to post Share on other sites
RandyLittrell 3,944 #3 Posted June 24, 2019 I have a VAC and they are too big to go on a 12 wheel for sure. They also weigh about a hundred pounds! About any weight you find for a garden tractor with 12" wheels will fit a WH. Randy Share this post Link to post Share on other sites
CCW 1,519 #4 Posted June 24, 2019 Thanks for the feedback. Guess I will be skipping these. Share this post Link to post Share on other sites
