Pat Marchwick 91 #1 Posted June 22, 2019 Is there a hydraulic Trouble shooting chart anywhere for wheelhorse hydrostatic and hydraulic system ? such as : Problem Possible cause tractor climbs slope fine in reverse but not in forward, . Bad spool valve ? tractor does not move. Low fluid, plugged fIlter ? lift cylinder works but tractor will not move. Bad shift linkage! Internal oil leak in valve? looking for help figuring out my tractor weird behavoir to go forward up a 15 degree incline I have to find a sweet spot with the directional handle. Too far it won't climb and irs not a lack of power. On level ground it works ok. thank you 1 Share this post Link to post Share on other sites
bc.gold 3,406 #2 Posted June 22, 2019 (edited) 44 minutes ago, Pat Marchwick said: Is there a hydraulic Trouble shooting chart anywhere for wheelhorse hydrostatic and hydraulic system ? such as : Problem Possible cause tractor climbs slope fine in reverse but not in forward, . Bad spool valve ? tractor does not move. Low fluid, plugged fIlter ? lift cylinder works but tractor will not move. Bad shift linkage! Internal oil leak in valve? looking for help figuring out my tractor weird behavoir to go forward up a 15 degree incline I have to find a sweet spot with the directional handle. Too far it won't climb and irs not a lack of power. On level ground it works ok. thank you From what your describing sounds like you have weak or broken spring the charts below are from the Sundstrand used in Allis and Simplicity. But the acceleration valve is a common component on all hydro units. Edited June 22, 2019 by bcgold Share this post Link to post Share on other sites
daveoman1966 3,839 #3 Posted June 22, 2019 What tractor... Sundstrand or Eaton ??? 1 Share this post Link to post Share on other sites
bc.gold 3,406 #4 Posted June 22, 2019 (edited) 9 hours ago, daveoman1966 said: What tractor... Sundstrand or Eaton ??? You mean this one. eaton.pdf Edited June 22, 2019 by bcgold Share this post Link to post Share on other sites
