Andy3120 1 #1 Posted June 13, 2019 It will run fine and I can get half of my garden tilled and it just shuts down. I just put on a new fuel pump and cleaned the carb. 1 Share this post Link to post Share on other sites
Guest 88vic #2 Posted June 13, 2019 Put a spark tester on it, run it and watch the tester. When it shuts down, verify if youve lost spark, if not then it would be a fuel related issue. Ive seen leaves, pine needles and even a petrified spider plug up the fuel outlet on the tank. Share this post Link to post Share on other sites
moe1965 774 #3 Posted June 14, 2019 I had a 301 that would shut down after running a while. Turned out the head was full of grass clippings under the shroud. Just a thought Share this post Link to post Share on other sites
953 nut 63,957 #4 Posted June 14, 2019 If the vent in your fuel cap is plugged up the fuel being used will develop a vacuum in the tank that the fuel pump can't overcome. Try running it with the cap backed off a half turn. If that is it you need a new fuel cap. 2 Share this post Link to post Share on other sites
Andy3120 1 #5 Posted June 14, 2019 1 hour ago, moe1965 said: I had a 301 that would shut down after running a while. Turned out the head was full of grass clippings under the shroud. Just a thought All clean under there I'm thinking it's something to do with fuel ive ran it with the hood off thinking it might be overheating but it still does the same thing. Share this post Link to post Share on other sites
ZXT 2,401 #6 Posted June 14, 2019 (edited) Does it start right back up afterwards? Does choking it make any difference? When a coil is breaking down, it will work fine cold, die out when it gets hot, and then start working again once it cools down. Easiest thing to do would be to check for spark with a tester, or if you don't have a tester, either pull the plug or put a known good plug on the spark plug wire and ground the base and see if you have spark. If you don't, bad coil. If you do, the gas cap probably isn't venting. Loosen it and see if it helps matters any. Edited June 14, 2019 by ZXT 1 Share this post Link to post Share on other sites
