noe 5 #1 Posted June 13, 2019 does anyone have any pic to show it? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,166 #2 Posted June 13, 2019 Are you asking about a snowthrower? The basic design never changed since 1973. The 516-H is a 1988 model. Garry 1 Share this post Link to post Share on other sites
ericj 1,579 #3 Posted June 13, 2019 I don't remember the exact correct hole but have been told it makes a difference on lift ease and height, which hole on the lift arm that you put the flag pin in. It's easy enough to swap hole if you don't like the ease of lift or the height. Also to raise lift height you can add washers over the shaft on the flag. good luck eric j 2 1 Share this post Link to post Share on other sites
noe 5 #4 Posted June 15, 2019 On 6/13/2019 at 10:29 AM, ericj said: I don't remember the exact correct hole but have been told it makes a difference on lift ease and height, which hole on the lift arm that you put the flag pin in. It's easy enough to swap hole if you don't like the ease of lift or the height. Also to raise lift height you can add washers over the shaft on the flag. good luck eric j I put it in the top hole buy what a different it makes. one hand Share this post Link to post Share on other sites
