JoeA 3 #1 Posted June 12, 2019 (edited) I have the parts manual for a 417-a says the drive belt part number is 7466. Is there a newer number for the drive belt ? Edited June 12, 2019 by JoeA Bad data in question Share this post Link to post Share on other sites
Skipper 1,792 #2 Posted June 12, 2019 7466 is the drive belt pulley on the engine if I'm not mistaken. 108501 would be the belt number If I read the chard right. That is a 81" B belt. Also known as B78K. You can pick those up for about 10-15$. I would recommend the blue stuff from TSC and others. 4 Share this post Link to post Share on other sites
JoeA 3 #3 Posted June 12, 2019 13 minutes ago, Skipper said: 7466 is the drive belt pulley on the engine if I'm not mistaken. 108501 would be the belt number If I read the chard right. That is a 81" B belt. Also known as B78K. You can pick those up for about 10-15$. I would recommend the blue stuff from TSC and others. Duuuuh Yes u are correct That explains why I could not find a belt that does not exist..... Looks like tractor supply TSC right down the road has a 5/8 X 81 Kevlar belt Thank you for the clarification..... Need to look closer at the part description next time 3 Share this post Link to post Share on other sites
peter lena 9,851 #4 Posted June 13, 2019 having a t/s close by makes a belt match easy , lucky you, pete Share this post Link to post Share on other sites
