RJ Hamner 1,029 #1 Posted June 11, 2019 Rebuilding a 69 Raider 12 I down to rebuilding the engine This one and my "donor" both have magnitos Would it be possible to swap out the magnito for a stator with the correct recifier and use the current flywheel?? Share this post Link to post Share on other sites
pfrederi 19,794 #2 Posted June 12, 2019 (edited) I think so. The magnets in the flywheel do not change. The stator would have to be changed. I believe it because i was messing around with a breakerless system awhile back and the flywheel part number for breakerless and battery were the same.... EDIT thinking some you would not have to change the stator. It would still have the charge portion (assuming this wan't a pull start engine) Edited June 12, 2019 by pfrederi 1 Share this post Link to post Share on other sites
Kenneth R Cluley 659 #3 Posted June 12, 2019 I modified same tractor over a year ago, didn't change stator. It has two separate coils, one for ignition , and one for charging. Share this post Link to post Share on other sites
ebinmaine 77,075 #4 Posted June 12, 2019 15 hours ago, RJ Hamner said: Rebuilding a 69 Raider 12 I down to rebuilding the engine This one and my "donor" both have magnitos Would it be possible to swap out the magnito for a stator with the correct recifier and use the current flywheel?? Here's a thread I keep in my email about the subject. Hope it helps.... Share this post Link to post Share on other sites
