Jesse Rieber 28 #1 Posted June 10, 2019 I bought a D160. The engine starts fine when fully choked. After it warms up a bit I try to ease off the choke and it stalls. Eventually, I can bring the choke all the way down. When I run the throttle full up it is reving fine, but then suddenly will slow and may stall. I have observed the arm to the carb that activates the throttle. When I put the throttle full ahead it seems to automatically back off and the engine revs drop. Anyone have any ideas about this? Share this post Link to post Share on other sites
pfrederi 19,284 #2 Posted June 10, 2019 D 160s came with 2 different engines over time. A Kohler single K341 or later an Onan Twin. Need to know which you have as some of us work with Kohlers some with Onans some with both. I know nada about Onans 1 Share this post Link to post Share on other sites
Jesse Rieber 28 #3 Posted June 11, 2019 This has an Onan engine, sorry thought I'd included that Share this post Link to post Share on other sites
pacer 3,177 #4 Posted June 11, 2019 Onans are notoriously 'finicky' when tuning. Since this is a new-to-you tractor/engine I would do a thorough fuel delivery cleaning - get rid of old gas, replace fuel lines/filters, check fuel pump, and very likely would need a carb cleaning and kit - ethanol fuel can really gum up everything. As for the throttle backing off, the lever operates on a friction basis - look under the dash and see if you can spot a nut that the lever pivots on, this may need a slight tightening. These "Big D's" are an awsome tractor!! Share this post Link to post Share on other sites
Jesse Rieber 28 #5 Posted June 11, 2019 Thanks. I did notice there is a triangular piece which is the connection between the dash throttle and the spring/arm mechanism and that the bolt on which the triangular piece swivels is loose. I'll give that a try Share this post Link to post Share on other sites
