Pullstart
Today’s haul
Pullstart
24 minutes ago, ebinmaine said:
Your gonna need to start following your screen name with the number of tractors like @WHX22
But I’m limited as to how many per month I can change...
  • Haha 2
Retired Wrencher
23 hours ago, pullstart said:
Room?  I never thought I’d fill up this 40x80 storage building!  I think I need to put up more raking before winter to get the camper inside!  Young... and while my kids enjoy it :handgestures-thumbupright:
Hopefully they will enjoy them when they are older. Keep the tradition going.
Pullstart
Almost a year this thing has been sitting.  Well... I think it will look good with a double wide belt guard sticking out the side of the hood!
  • Excellent 4
Pullstart
The 552 frame looks good, feels fairly tight!  The fan gear support is cracked on one side, I bet I have a spare!
Pullstart
Here Tom!  Here Jerry!  Come out with your hands up!
  • Haha 4
  • Sad 1
Pullstart
I’m thinking I smell some Silvertowne duals :D
  • Excellent 3
953 nut
Bet you have more than one spare!               :laughing-rolling:
  • Haha 1
Pullstart
Though I likely won’t reuse this plate on the 1055, someone did a decent job building it!  It bolts to the rear tins, then the fender is sandwiched to the seat.
Pullstart
Pullstart
It’s moved over.  I see the coil will need to move a bit to clear the hood.
Pullstart
The muffler had to come off to clear the hood.  Bummer.  I’ll have to give it a stack I guess.  :ROTF:
The air cleaner is too deep to clear the hood too.
Pullstart
The belt guard from the 1055 I believe was modified for the K-161.  It works best.
Pullstart
I need to swap transmissions too.  The 552 trans is stuck and won’t roll.
  • Sad 1
Pullstart
552 trans is out.  Not surprisingly, the frame is cracked but has been plated well from the inside.
This’ll be a perfect time to replace the broken steering block too.
  • Like 5
Pullstart
Steering fixed up, dash upright supports are in place.
D_Mac
Yeah Kevin That sounds like a quick and easy project < eye roll >.
  • Haha 3
Pullstart
Pullstart
What’s that hot rod saying?  “Cheap, fast and reliable.  You pick two.“
  • Heart 2
Pullstart
I accidentally put the transmission pulley on backwards.  No big deal, but now the set screw I just tightened seems stripped out!
Pullstart
I was able to find a hex key just slightly bigger and pound it in.  Yay!
Pullstart
Hubs are snugged up, seat is on along with the belt guard.
  • Like 4
Pullstart
A guy’s gotta kinda hand it to whoever took the time to make this head tin!
  • Like 4
ebinmaine
Agreed. That's good work. I'd paint it and run it.
Pullstart
I hooked some juice to the coil and pulled the engine over with a piece of twine wrapped around the pulley.  I have spark!
The s/g doesn’t spin too fast, so I took it apart for inspection.  It looked good and spins well, so I cleaned up the armature and put it back together.  Still doesn’t spin too good.
Pullstart
