chev0545
418 kohler
chev0545
will a 18 kohler fit in a 417-a with kohler
thanks
ZXT
Was this 18hp engine out of a Horse? If it wasn't, the crank diameter and length might be different.
chev0545
it was out of a 418-h
pfrederi
I am assuming the 18 is a Magnum 18  from a 418A  (there was no 418 H that i am aware of)  Spec number in the 18 should be 24510 if so it will fit.  However you will have to do some rewiring and get a new ignition switch as you are going from a battery points to a Magneto system
richmondred01
Yes. The m18 Kohler (wheel horse spec) will replace the kt17. Like pfrederi said the wiring will need to be tweaked.
The m18 is a great engine.
I have seen them with 2500+ hours.
