wshall2   1 #1 Posted May 29, 2019 Hi, I recently purchased a garden tractor and it came with a TORO mower deck (although it is a different brand ) the mower deck was never used on this tractor and possibly (based on look of the underside ) never used ever. Before I attempt to modify it to work on my tractor, I thought it may be worth finding out if it was of any value to wheelhorse owners looking for an original deck? On the tag on the top (which is very faded ) I did make out the TORO name, but stopped looking further, let me know if you need me to see if I can get more numbers off of it to help identify it and its value/interest?  1 Share this post Link to post Share on other sites
71_Bronco   1,072 #2 Posted May 29, 2019 I would personally not modify it.  Not sure what the value would be, as they vary quite a bit (depending on condition, age, models it fits, etc). I am not an expert on this style deck.  What model tractor did it come with? Share this post Link to post Share on other sites
WVHillbilly520H Â Â 10,378 #3 Posted May 29, 2019 Looks to be for the xi series...44"? Share this post Link to post Share on other sites
clueless   3,403 #4 Posted May 29, 2019 Looks like it still has the model and serial number on it. Give us those and Garry will figure it out . Share this post Link to post Share on other sites
wshall2 Â Â 1 #5 Posted May 30, 2019 8 hours ago, 71_Bronco said: I would personally not modify it. Â Not sure what the value would be, as they vary quite a bit (depending on condition, age, models it fits, etc). I am not an expert on this style deck. Â What model tractor did it come with? It came with a case tractor I just bought, PO picked it up years back to put on that case tractor but never touched it, not sure the original one it came with Share this post Link to post Share on other sites
wshall2   1 #6 Posted May 30, 2019 5 hours ago, clueless said: Looks like it still has the model and serial number on it. Give us those and Garry will figure it out . I will inspect the tag again tomorrow, was very faded Share this post Link to post Share on other sites
gwest_ca-(File Mod)   12,259 #7 Posted May 30, 2019 Will guess it is a 48" width of cut model 78363 so one of these https://www.wheelhorseforum.com/search/?&q=78363&type=downloads_file&search_and_or=or&sortby=relevancy  Garry Share this post Link to post Share on other sites
wshall2   1 #8 Posted May 30, 2019 4 hours ago, gwest_ca said: Will guess it is a 48" width of cut model 78363 so one of these https://www.wheelhorseforum.com/search/?&q=78363&type=downloads_file&search_and_or=or&sortby=relevancy  Garry Gary, I think you may be right on the model, I just went out and as can be seen from this picture, the model number is partially damaged on the tag, but I can make out "363" and what looks like an "8" in front of that, and it does measure 48" wide, each blade is 16".   That being found, what mower would this have been for, and is there any interest in it? What would it potentially be worth? Still trying to determine if I modify it to fit my tractor, or sell it and try to find the correct deck for my tractor. Thanks  Share this post Link to post Share on other sites
WVHillbilly520H   10,378 #9 Posted May 30, 2019 18 minutes ago, wshall2 said: Gary, I think you may be right on the model, I just went out and as can be seen from this picture, the model number is partially damaged on the tag, but I can make out "363" and what looks like an "8" in front of that, and it does measure 48" wide, each blade is 16".   That being found, what mower would this have been for, and is there any interest in it? What would it potentially be worth? Still trying to determine if I modify it to fit my tractor, or sell it and try to find the correct deck for my tractor. Thanks  Xi series attachments are not as easy for us to find...i recommend you list in the classifieds and start looking for a deck to fit your CASE...JMHO... Share this post Link to post Share on other sites
gwest_ca-(File Mod) Â Â 12,259 #10 Posted May 30, 2019 The 78363 serial number will be 8902081 making it a 1998 model. Pretty important that you don't loose those numbers. Â Garry 1 Share this post Link to post Share on other sites
wshall2   1 #11 Posted May 30, 2019 24 minutes ago, gwest_ca said: The 78363 serial number will be 8902081 making it a 1998 model. Pretty important that you don't loose those numbers.  Garry Thanks for the info. Only had it for less than a week and just looked at the tag for the first time today, got a picture so even if the tag gets worse, I have that.  Share this post Link to post Share on other sites
23 Reo   235 #12 Posted June 1, 2019 You have a really nice deck. I would sell it  for $350 to $400 and use the money toward the purchase of the correct deck for your Case. 1 Share this post Link to post Share on other sites
doc724   925 #13 Posted June 1, 2019 It is definitely a deck for an xi tractor. It looks to be in pretty pristine shape on the underside but it was outside for a long time as witnessed by the faded paint topside. Depending on local demand, you could easily get $350-400 as suggested by 23 Reo 1 Share this post Link to post Share on other sites
wshall2   1 #14 Posted June 1, 2019 2 hours ago, doc724 said: It is definitely a deck for an xi tractor. It looks to be in pretty pristine shape on the underside but it was outside for a long time as witnessed by the faded paint topside. Depending on local demand, you could easily get $350-400 as suggested by 23 Reo Thanks for the tips guys, I appreciate it! Share this post Link to post Share on other sites
