Dominator
Koehler 14 magnum
Dominator
Hello all, wondering about the main differences between a Kohler cast iron 14 and the newer magnum 14.  Is one better than the other and it what way?  I have read that the magnum benefits from changing the walbro carb.  Just trying to make some sense, any help is greatly appreciated,. Thank you dominator
troutbum70
The builders always what us to believe newer is better, and maybe in this that is true. I knew a guy that swapped out a cast one for the newer in a cub cadet, but am not sure if he ever benefitted from the swap. Will be interesting to see others opinion.
Dakota8338
Personally I prefer the old cast iron k-three hundred series Kohler engines myself.  Preferences admittedly does not make one better or worse, just my opinion for what its worth.
