troutbum70 858 #1 Posted May 28, 2019 Not sure what allowed the pto hub to move out so far from friction disc and it will no longer engage. Included are a couple pictures. Top picture is the pto disassembled. Also found a lot of fine black residue the roller bearing in the hub has a lot of it packed around it. Share this post Link to post Share on other sites
Lee1977 7,638 #2 Posted May 28, 2019 It looks to me that the pulley and clutch disk have moved back too far. May just be the picture but it looks like the clutch disk is rubbing the belt guard. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,276 #3 Posted May 28, 2019 Has the engine been replaced? Crankcase looks like aluminum. Garry Share this post Link to post Share on other sites
troutbum70 858 #4 Posted May 28, 2019 Yes you are correct Lee1977 the disc is rubbing the very bottom of the belt guard and I did not see it, thank you for your observation. And yes gwest it is no longer a cast iron block it was replaced by one of the previous owners. I am not sure what the life expectancy is of the aluminum block is, but I don't really run it a lot so it will last me a while, according to the tag it is still a k181. Share this post Link to post Share on other sites
Pullstart 70,103 #5 Posted May 30, 2019 On 5/28/2019 at 5:20 PM, gwest_ca said: Has the engine been replaced? Crankcase looks like aluminum. Garry On 5/28/2019 at 7:27 PM, troutbum63 said: Yes you are correct Lee1977 the disc is rubbing the very bottom of the belt guard and I did not see it, thank you for your observation. And yes gwest it is no longer a cast iron block it was replaced by one of the previous owners. I am not sure what the life expectancy is of the aluminum block is, but I don't really run it a lot so it will last me a while, according to the tag it is still a k181. Is that the grey replacement block color? Still looks like a cast block... short of the aluminum color. Share this post Link to post Share on other sites
troutbum70 858 #6 Posted May 30, 2019 Actually LEE1977 got me to wondering about it because I had never really thought about it so today I put a magnet on it and its iron. The person I bought it from in Kentucky was not the one that had replaced the engine and he really never ran the tractor much, so I think it has seen little use until I bought and all I do is pull the yard around with it. I don't think the entire tractor ever seen much use so not sure why the engine even needed replaced, the deck and all is as solid as new, so if it ever done any mowing it was well cleaned after each use. Share this post Link to post Share on other sites
