sawyer 0 #1 Posted April 5, 2009 There is a little seal that is leaking transmission fluid on my 69' charger 12. The seal is behind the shaft that makes it go forward or rerverse. it leaks bad and it says, (Torrington B-1210). I'd say i can find a seal at Orielly's but my question is how do you get the old seal out. It is pretty small width wise about 3/16" and about 3/4" center were it goes around the shaft. I sure don't like leaks on my nice concreate Thanks for the input. Share this post Link to post Share on other sites
sawyer 0 #2 Posted April 5, 2009 I googled the number and its not a seal its a needle bearing. So my leaks must be coming from the o-rings. Share this post Link to post Share on other sites
Bow_Extreme 580 #3 Posted April 6, 2009 You know I was just working on a seal and bearing in my 520 tonight. IT also states Torrington and mine has a bearing and a seal. They are both seperate from each other. Maybe your seal is gone. Share this post Link to post Share on other sites
