clueless 3,348 #1 Posted May 24, 2019 I've got a '88 37" two blade deck, also have the bagger chute that bolts to the deck. Looking for how it bolt up to the deck, I know it's just a couple of bolts and nut, but on my JD bagger the bolts bolt through a plate and stay on the deck even when the deck is removed. Not sure if I'm making myshelf clear. The manual would help. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #2 Posted May 24, 2019 May be something here you can use https://www.wheelhorseforum.com/search/?&q="07-07BC01"&type=downloads_file&search_and_or=or&sortby=relevancy Garry Share this post Link to post Share on other sites
clueless 3,348 #3 Posted May 24, 2019 40 minutes ago, gwest_ca said: May be something here you can use https://www.wheelhorseforum.com/search/?&q="07-07BC01"&type=downloads_file&search_and_or=or&sortby=relevancy Garry Thanks Garry, I saw those but not showing how the chute bolts up. I'm sure you use the two bolts that hold the discharge chute on, same bolt hole pattern. Just don't know if you remove the discharge chute or not, mine is missing. Was hoping there might an operation/ installation manual, no big deal it will do what I want it do. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #4 Posted May 24, 2019 I think what you want is on the first page of the operator manual Garry Share this post Link to post Share on other sites
rlrnot 39 #5 Posted May 25, 2019 Remove the deflector chute and attach the bagger chute using the same holes and hardware. Share this post Link to post Share on other sites
clueless 3,348 #6 Posted May 25, 2019 17 hours ago, gwest_ca said: I think what you want is on the first page of the operator manual Garry Thanks Garry, once again you nailed it . Share this post Link to post Share on other sites
