william orndorff 7 #1 Posted May 24, 2019 I just had my third after market (cheap) mechanical fuel pump quit on my 312-8. Thinking about an electric pump. I assume I'll need a low pressure pump. Any suggestions on the particular specs or where to find one? The lady of the house has forbidden me to buy mechanical pump from Toro at $189.00. Share this post Link to post Share on other sites
pfrederi 19,096 #2 Posted May 24, 2019 (edited) I use Facet Posi flo. get one with 4psi or less. I get mine from Spruce aviation. https://www.aircraftspruce.com/catalog/eppages/solidstatepump.php Around $35-40 and i figure if they use them in planes where fuel pump failure is big deal should be reliable enough for my WH. Oldest one is going on 4-5 years now. Edited May 24, 2019 by pfrederi 5 Share this post Link to post Share on other sites
Retired Wrencher 6,116 #3 Posted May 25, 2019 William I hope this works out for you./ Thanks for the info Paul. I put in my favorites section. Good to know. Share this post Link to post Share on other sites
953 nut 62,646 #4 Posted May 25, 2019 On 5/24/2019 at 11:22 AM, william orndorff said: The lady of the house has forbidden me to buy mechanical pump from Toro at $189.00. Thank her for not letting you waste your money! I have had good luck with the low pressure electric pumps sold on Share this post Link to post Share on other sites
william orndorff 7 #5 Posted May 26, 2019 Thanks for the help men . I know I need a pump that puts out 4 psi or less. How about flow rate? Are they all pretty much the same? Also should they be mounted close to the fuel tank? Share this post Link to post Share on other sites
kasey54 305 #6 Posted May 26, 2019 I have a couple, they just need to be mounted low. Works great. 1 Share this post Link to post Share on other sites
