71_Bronco 1,072 #1 Posted May 23, 2019 I have a 1968 Commando 8 with the 8hp K181 Kohler. With the tractor, I got a plow blade w/ frame, rear axle mounts, and lift link, as well as a 36" rotary gear-drive deck. I am hopefully going to be attaching the deck this weekend, and I am not sure what hole to put the link on. I thought I saw a picture at one time, showing the lift holes and what they are typically used for, but I cannot seem to find that at the moment. When I got the tractor, the link for the plow was on the tractor, but I took it off, and stupid me forgot to note what hole it was attached to. At some point down the road, I will also be installing a new lift cable for the slot-hitch. My old cable was shot, so I had to remove it. If someone can show the correct hole for that as well, it would be very much appreciated. Thanks! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,510 #2 Posted May 23, 2019 Good question and often asked so put a file together you can print out. This is from a later model but likely still applies to yours. This is from an illustrated parts list. Click on the picture Garry 2 Share this post Link to post Share on other sites
71_Bronco 1,072 #3 Posted May 23, 2019 27 minutes ago, gwest_ca said: Good question and often asked so put a file together you can print out. This is from a later model but likely still applies to yours. This is from an illustrated parts list. Click on the picture Garry Garry, Thanks so much! That is exactly the picture I was looking for. 1 Share this post Link to post Share on other sites
