Jennifer 1,878 #1 Posted May 18, 2019 (edited) Could anyone tell me what this deck if for? What is it worth? Would it work on B-100?? Edited May 18, 2019 by Jennifer Share this post Link to post Share on other sites
953 nut 59,789 #2 Posted May 18, 2019 11 minutes ago, Jennifer said: What is it worth? Would it work on B-100?? That would be a yes and no answer. The deck is missing several mounting parts and would probably cost more to repair than it would cost to buy a good working deck. Share this post Link to post Share on other sites
daveoman1966 3,839 #3 Posted May 18, 2019 It'll work of you change the LIFT HARDWARE to one like this. I have all the parts you need to do that This is a 42" deck...but the hardware is the same 2 Share this post Link to post Share on other sites
Jennifer 1,878 #4 Posted May 18, 2019 Ok so I have these decks! Are they the same? What are they for? As far as mower? I am trying to find what the deck for the B-100. Share this post Link to post Share on other sites
953 nut 59,789 #5 Posted May 18, 2019 The two decks in the second picture will work if you have the Mule Drive on the front of your B-100. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,450 #6 Posted May 18, 2019 ID plate should have the model number, serial number and possibly the Julian build date Garry Share this post Link to post Share on other sites
Jennifer 1,878 #7 Posted May 18, 2019 2 minutes ago, gwest_ca said: ID plate should have the model number, serial number and possibly the Julian build date Garry The deck you circled was a sticker and unreadable the rear discharge has a metal tag! What style deck did the b-100 come out with? Share this post Link to post Share on other sites
Jennifer 1,878 #8 Posted May 18, 2019 41 minutes ago, daveoman1966 said: It'll work of you change the LIFT HARDWARE to one like this. I have all the parts you need to do that This is a 42" deck...but the hardware is the same Is the nice painted one for sale? Share this post Link to post Share on other sites
Jennifer 1,878 #9 Posted May 18, 2019 13 minutes ago, 953 nut said: The two decks in the second picture will work if you have the Mule Drive on the front of your B-100. How do they hook up? Share this post Link to post Share on other sites
953 nut 59,789 #10 Posted May 18, 2019 Read over this post Karl did on removing a deck and do the reverse order to install it. Best to grease the spindles and check everything over first. 1 Share this post Link to post Share on other sites
Jennifer 1,878 #11 Posted May 18, 2019 2 minutes ago, 953 nut said: Read over this post Karl did on removing a deck and do the reverse order to install it. Best to grease the spindles and check everything over first. Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,450 #12 Posted May 18, 2019 Click on the picture. This is for the ID plate you posted but installation instructions are the same for all. Garry 1 1 Share this post Link to post Share on other sites
