cleat 8,543 #26 Posted July 23, 2019 Those are the best pulleys. Your project is looking great so far. Share this post Link to post Share on other sites
AMC RULES 37,254 #27 Posted July 23, 2019 Can we see the RJ you're working on too? Share this post Link to post Share on other sites
76c12091520h 4,039 #28 Posted July 24, 2019 I knew when I took the picture that someone was going to spy the Clinton parts lurking in the background, you were my first guess. They are for our 61 Suburban which came Clinton powered; that one's up next! 1 Share this post Link to post Share on other sites
76c12091520h 4,039 #29 Posted July 29, 2019 Pulled the deck off and put it back on my C120, will be tearing this down soon; I'm installing a foot pedal kit first and want to test it before I tear it down. In the meantime I pulled the front wheels , stripped and refinished, and replaced the original 16-7.50 x 8's with 18-8.50 x 8's and filled the front tires; added nearly 50lbs to the front end. Used a small garden pond pump submersed in washer fluid, each tire took about 3 gallons. Added a little bling too..... 5 3 Share this post Link to post Share on other sites
76c12091520h 4,039 #30 Posted August 7, 2019 Deck is done, and I already had an offer on it! Not for sale but the $$$ was hard to pass up...…. 8 10 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,603 #32 Posted August 7, 2019 Just looking at this thread. WOW you are doing it right!! Share this post Link to post Share on other sites
Bertie 314 #33 Posted August 7, 2019 Great attention to detail... presume its for shows only 🤔 Share this post Link to post Share on other sites
Shed 371 #34 Posted August 8, 2019 I remember my mom when the 416 was dropped off the deck was so clean like yours 1800 hours later still cuts nicer then my new zero turn 1 Share this post Link to post Share on other sites
76c12091520h 4,039 #35 Posted August 9, 2019 Started pulling tins off to install the foot pedal kit, so I did the 520 Onan side cover mods prior to sandblasting, don't want it overheating. Will probably cover the holes with some type of screen on the inside for cosmetic purposes: 4 2 Share this post Link to post Share on other sites
76c12091520h 4,039 #36 Posted August 26, 2019 Finally was able to take some time today and work on some of my Horse projects: finished installing and adjusting the hydro pedal kit before I tear it all down. It fit's and works ok but I will be modifying it to suit before the final install. Also gave it a good pressure washing. The next time you see it, it will be in pieces 4 Share this post Link to post Share on other sites
Burnerman 759 #37 Posted August 26, 2019 Wow! Very nice! Talk about better then new! Share this post Link to post Share on other sites
76c12091520h 4,039 #38 Posted September 18, 2019 Been too busy sorting parts and tearing this down to get any pictures posted so here's a quick update: repaired and refinished the gauge panel(had a lot of gouges and marks from the hood rubbing), and replaced the right rear axle seal(only leak on the whole tractor) 4 Share this post Link to post Share on other sites
R. L. Addison 300 #39 Posted September 18, 2019 I admire your craftsmanship. Excellent job. Share this post Link to post Share on other sites
76c12091520h 4,039 #40 Posted September 19, 2019 A freshly cleaned and primed hub(that didn't break taking it off!), A little anti-seize, and wheel studs! Also welded the extra holes shut on the rear fenders that aren't covered completely by the taillights. 2 2 Share this post Link to post Share on other sites
Pullstart 68,700 #41 Posted September 20, 2019 How do you duplicate the texture of the dash panel? You are doing great work! Share this post Link to post Share on other sites
trailhopper 50 #43 Posted October 2, 2019 On 8/8/2019 at 10:04 PM, 76c12091520h said: Started pulling tins off to install the foot pedal kit, so I did the 520 Onan side cover mods prior to sandblasting, don't want it overheating. Will probably cover the holes with some type of screen on the inside for cosmetic purposes: Super clean restoration. Great idea on venting the engine heat from the rear cylinder. What did you use to cut the holes for your engine vent? Hole saw? Step drill? -Scott 1 Share this post Link to post Share on other sites
76c12091520h 4,039 #44 Posted October 3, 2019 Marked a straight line to match the angle of the cover, drilled a 1/8" pilot hole, then used a 3/4" step drill on each end, then I clamped a piece of straight steel stock down for a cutting edge and cut the long straights with a cutoff wheel. 1 1 Share this post Link to post Share on other sites
76c12091520h 4,039 #45 Posted October 31, 2019 Well I guess you can call this progress; all the Sheetmetal and the rear wheels are being blasted , a few small parts have been disassembled , and these late models REALLY have too much electrical on them ! 6 Share this post Link to post Share on other sites
76c12091520h 4,039 #46 Posted December 2, 2019 (edited) Got a BIG pile of parts back from the sandblaster (25 total) and epoxied them Saturday. Painted the rear wheels and cleared them right away since they're the only silver parts left to paint. Cleaned and detailed the fuel sending unit and made a new gasket. Edited December 2, 2019 by 76c12091520h 3 3 Share this post Link to post Share on other sites
balconio 606 #47 Posted December 2, 2019 brilliant idea on those bronze hood bushings... i was going to try and cheap out and squeeze some rubber ones in there but i don't think i'll be happy with them over time. the originals are completely gone and the hood rocks significantly in either direction. Share this post Link to post Share on other sites
76c12091520h 4,039 #48 Posted December 4, 2019 When I epoxied the hood, I taped off a 1/2" strip on top of the hood seam. Welded it solid and began smoothing it in...…..the great thing about the epoxy primer is that you can do your body work right over top of it. 1 1 Share this post Link to post Share on other sites
76c12091520h 4,039 #49 Posted December 9, 2019 Painted a whole lotta satin black parts yesterday, reassembled the gauge panel and detailed and restored the gauges as needed(new decals after it's assembled). Installed new tires (24x12's) and inside weights. 1 4 1 Share this post Link to post Share on other sites
