Exlr82fast 8 #1 Posted May 14, 2019 (edited) I bought a 1941 John Deere LA that has a Ark 550 loader that someone has put on it. I was told the loader was off of a WH D250 there is some red paint here and there. I fell in love with it as soon as I seen it. I've never jumped on the team GREEN band wagon. But here we are. I hope even though it is not red you guys might still help me out. I'm in the process or rebuilding the cylinders the seals were shot. I have read that it's a good idea to put a filter on the system. So was curious if anyone has done this? Also to trouble shoot I hear of people saying to put a gauge on it and so forth. What sorta pressure or psi will this system produce? Gauges range from 0-100psi 0-300psi ect. So what is appropriate? The pump pulley is slipping but I think I can engineer a better bracket to tighten the belt but I'm a little worried it may be going out but I have my fingers crossed. I may have more questions as I dig into this any help would be great. Edited May 14, 2019 by Exlr82fast 4 Share this post Link to post Share on other sites
WHX?? 53,703 #2 Posted May 14, 2019 Nice setup I'm sure the loader/hydraulic experts here will be along to help. Share this post Link to post Share on other sites
Exlr82fast 8 #3 Posted May 14, 2019 Thanks for the welcome! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,918 #4 Posted May 14, 2019 Here is what we have on the Ark loader. The Simplicity model shows 1250 psi but may be a model with a higher capacity. https://www.wheelhorseforum.com/search/?&q=ark&type=downloads_file&search_and_or=or Garry 1 Share this post Link to post Share on other sites
oliver2-44 11,137 #5 Posted May 14, 2019 That,s a neat setup, even if it is green. John Deere copy rights there manuals, so they are hard to find free online. They are for sale online, that would be a good place to start if you don't have one. I'm not familiar with an LA model, but a John Deere B All Fuel Model has 70 PSI and Gas Model has 110 PSI compression. You might post your question at https://www.yesterdaystractors.com good friendly, helpful people on that site as well. Keep us posted on what you learn and any repairs you make. Share this post Link to post Share on other sites
Exlr82fast 8 #6 Posted May 14, 2019 45 minutes ago, gwest_ca said: Here is what we have on the Ark loader. The Simplicity model shows 1250 psi but may be a model with a higher capacity. https://www.wheelhorseforum.com/search/?&q=ark&type=downloads_file&search_and_or=or Garry Thank you that will be nice to have I'll print those off. 1 Share this post Link to post Share on other sites
Exlr82fast 8 #7 Posted May 14, 2019 17 minutes ago, oliver2-44 said: That,s a neat setup, even if it is green. John Deere copy rights there manuals, so they are hard to find free online. They are for sale online, that would be a good place to start if you don't have one. I'm not familiar with an LA model, but a John Deere B All Fuel Model has 70 PSI and Gas Model has 110 PSI compression. You might post your question at https://www.yesterdaystractors.com good friendly, helpful people on that site as well. Keep us posted on what you learn and any repairs you make. This set up is using the hydro pump that came with the loader I assume. The LA doesn't have any hydraulics of it's own. I wish it did I'm a bit concerned that the WH D250 had 20hp rpm of 3600 is a bit different from the JD LA 14hp 1800rpm. Share this post Link to post Share on other sites
Pullstart 68,604 #8 Posted May 14, 2019 34 minutes ago, oliver2-44 said: That,s a neat setup, even if it is green. John Deere copy rights there manuals, so they are hard to find free online. They are for sale online, that would be a good place to start if you don't have one. I'm not familiar with an LA model, but a John Deere B All Fuel Model has 70 PSI and Gas Model has 110 PSI compression. You might post your question at https://www.yesterdaystractors.com good friendly, helpful people on that site as well. Keep us posted on what you learn and any repairs you make. I think he”s talking hydraulic pressure for the pump? 1 Share this post Link to post Share on other sites
Pullstart 68,604 #9 Posted May 14, 2019 Where are my manners? to @Exlr82fast 1 Share this post Link to post Share on other sites
pfrederi 19,451 #10 Posted May 14, 2019 How I put one on my D200. Could have been simpler plumbing but I used what I had lying around. Filter set up came from Northern Tool 3 Share this post Link to post Share on other sites
Achto 30,435 #11 Posted May 14, 2019 Really nice looking LA!! You even have the hard to find lower nose piece on the front. A lot of the lower nose pieces are missing from the LA's. It had to be removed in order to attach some implements and was often times never put on again. Share this post Link to post Share on other sites
953 nut 63,542 #12 Posted May 14, 2019 I don't have any Green in my barn, but if I did it would be a LA for sure. 1 1 Share this post Link to post Share on other sites
roadapples 6,985 #13 Posted May 15, 2019 (edited) Nice looking tractor considering the color.... But it looks a lot harder to work on than a Edited May 15, 2019 by roadapples 1 Share this post Link to post Share on other sites
Exlr82fast 8 #14 Posted May 16, 2019 On 5/14/2019 at 1:37 PM, Achto said: Really nice looking LA!! You even have the hard to find lower nose piece on the front. A lot of the lower nose pieces are missing from the LA's. It had to be removed in order to attach some implements and was often times never put on again. I didn't know that....thank you I'm glad it's there. I really dont know much about them bit I fell in love with it when I seen it. Share this post Link to post Share on other sites
Exlr82fast 8 #15 Posted May 16, 2019 As of now I have the hood off...and i made a new adjustable bracket to tighten the pump. The old one had the bracket welded to the same piece that the pump was mounted. So if I begged down it would flex the unit as a whole and the belt would slip. I think I will have it right now. I'll post pics when I get it all mounted up. Thanks for the replies guys I'm really proud of this machine. Share this post Link to post Share on other sites
Achto 30,435 #16 Posted May 16, 2019 46 minutes ago, Exlr82fast said: I really dont know much about them bit I fell in love with it when I seen it. They are cool little tractors, even if they are green & yellow . Just wondering if by chance the serial number tag is still there? It was a brass tag that was riveted about center on the rear axle. This were prone to getting knocked off, most times all you will find is the rivet holes. I will have to see if I can find a picture of my dad's LA to share with you. Share this post Link to post Share on other sites
The Tuul Crib 7,340 #17 Posted May 16, 2019 That era of john deeres was dear to to to me and always will be. We had the big ones, three too be exact . I would do the plowing for my dad with one of them. We had a three or four bottom plow and l enjoyed watching that coal black lowa soil turn over . Looks great and thanx for sharing it with us. to 1 Share this post Link to post Share on other sites
Exlr82fast 8 #18 Posted May 18, 2019 (edited) On 5/16/2019 at 12:03 PM, Achto said: They are cool little tractors, even if they are green & yellow . Just wondering if by chance the serial number tag is still there? It was a brass tag that was riveted about center on the rear axle. This were prone to getting knocked off, most times all you will find is the rivet holes. I will have to see if I can find a picture of my dad's LA to share with you. It dose have the tag I cant remember what the numbers are but it is there. I'd like to see it. I live in Broadway Va there are 2 good sized tractor shows here and several parades around. I've only seen one that I know of little rare in these parts. Edited May 18, 2019 by Exlr82fast Share this post Link to post Share on other sites
Exlr82fast 8 #19 Posted May 18, 2019 Well I did it! Today I had my parts list gathered everything up in town. Got home this evening rebuilt the cylinders and got my pump bracket mounted up. Fired it up and it works great. Didn't get to start it till dusk so it was to dark for pics bit I'll upload some tomorrow. Thanks guys 3 Share this post Link to post Share on other sites
ronhatch 410 #20 Posted May 20, 2019 Love pre-1960 Green and Yellow! I don't care what you guys say, about JDs, the sound of that 2 cylinder working hard brings tears to my eyes and that hand clutch! WELL! what can I say? Both my grandpas and my uncles had model "A" when I was growing up. Care to guess what I was driving back then? Share this post Link to post Share on other sites
Exlr82fast 8 #21 Posted May 20, 2019 Here's a couple shots of what I did to the pulley. First pic is what it came with. Was a piece of 3/8s all thread going threw a bracket that was welded to the bracket that holds the pump. Under load the whole thing would rock to where it slipped the belt. Second was what I made. I made the assembly so I can take it apart easier and it is attached to the fan pulley bolt. No more slipping that's for sure. Share this post Link to post Share on other sites
Pullstart 68,604 #22 Posted May 22, 2019 On 5/20/2019 at 1:18 PM, Exlr82fast said: Here's a couple shots of what I did to the pulley. First pic is what it came with. Was a piece of 3/8s all thread going threw a bracket that was welded to the bracket that holds the pump. Under load the whole thing would rock to where it slipped the belt. Second was what I made. I made the assembly so I can take it apart easier and it is attached to the fan pulley bolt. No more slipping that's for sure. That looks a little tiny bit more robust! Share this post Link to post Share on other sites
