Firebug 267 #1 Posted May 10, 2019 I’m changing the deck on my 314 from a r/d to a s/d. Having a heck of a time getting it lined up. I have the tensioner all the way out. Is there a difference in belt length between the 2 decks that would allow more travel for lining things up? Share this post Link to post Share on other sites
peter lena 10,016 #2 Posted May 10, 2019 there is a belt difference of about 6" in length , as far as lining things up , the deck frame is the same dimension , make sue its INSIDE THE WIDTH OF THE TACH A MATIC FOWARD MOUNT. the line up on either deck should be the same, only the pto drive belt is different. is that the issue ? pete Share this post Link to post Share on other sites
Firebug 267 #3 Posted May 10, 2019 Yes that’s the issue, not long enough to move the deck back to line up the brackets. Do you know what length that belt is? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,456 #4 Posted May 10, 2019 Drive belt 102741 (1/2" x 96.6") for C-Series tractors (Gates replacement BladeRunner 6638BR 17/32" x 96.75") From what I see the side and rear discharge decks used the same drive belt. Perhaps the deck you have was from a medium frame tractor which used a shorter belt Drive belt 102607 (1/2" x 89.12") when used on medium frame 43-1/2" wheelbase tractors There may be a problem with clearance between the rear tractor tires and the deck. They do not list a 36" side discharge deck for the 314. Rear discharge only. The last 36" side discharge deck made was in 1984 and 1985 was the first year for the 300-Series. Garry Share this post Link to post Share on other sites
Firebug 267 #5 Posted May 10, 2019 I believe they are both 42 inch decks, on a 314 not a series of that makes a difference Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,456 #6 Posted May 10, 2019 Sorry about that. 42" rear discharge drive belt 108834 (1/2" x 98") 42" side discharge drive belt 102742 replaced by 94-2501 (1/2" x 103") 5" difference so that should move the deck back 2-1/2" Garry Share this post Link to post Share on other sites
Firebug 267 #7 Posted May 10, 2019 That sounds like it would do it Share this post Link to post Share on other sites
