Matash 15 #1 Posted May 9, 2019 Has anyone had the issue of engine sputter when hitting bumps.? I’m having this issue and I need to figure this out. Thanks Matt 314-H Share this post Link to post Share on other sites
squonk 44,918 #2 Posted May 9, 2019 Loose connection (Ignition) seat switch out of adjustment or erratic carb float level 8 1 Share this post Link to post Share on other sites
pacer 3,177 #3 Posted May 9, 2019 Have you recently put one of the cheap import carbs on it lately?? The last one I bought does this -- it allows the fuel in the bowl to 'slosh' which dumps added fuel into the engine. Imagine pulling the choke briefly. I intend to -- some day? -- go into it and see if it has the proper full cover gasket along with the o-ring one. I got a feeling it doesnt.... Share this post Link to post Share on other sites
Matash 15 #4 Posted May 9, 2019 6 hours ago, squonk said: Loose connection (Ignition) seat switch out of adjustment or erratic carb float level Thanks for the reply I’ll check those out today. It started last week and is getting worse. Share this post Link to post Share on other sites
Matash 15 #5 Posted May 9, 2019 1 hour ago, pacer said: Have you recently put one of the cheap import carbs on it lately?? The last one I bought does this -- it allows the fuel in the bowl to 'slosh' which dumps added fuel into the engine. Imagine pulling the choke briefly. I intend to -- some day? -- go into it and see if it has the proper full cover gasket along with the o-ring one. I got a feeling it doesnt.... It’s all original other than new blades Share this post Link to post Share on other sites
