Randy_in_Ohio 99 #1 Posted May 7, 2019 The turf saver tires on my 312-8 are terrible. I have 4 acres of swampy land and these tires have to go. Has anyone used these SunF G003? I have 23x9.5-12 on it now and these are 23x10.5-12 which should be just a little wider and shouldn't be a problem (i don't think so anyway). Do you think these will keep me from getting stuck in wet grass/mud? Any other recommendations? Share this post Link to post Share on other sites
Retired Wrencher 6,977 #3 Posted May 7, 2019 Randy I am sure some will chime in this. Lots tire people here to help. Share this post Link to post Share on other sites
953 nut 69,133 #4 Posted May 7, 2019 Those look a lot like the ones @Sparky has and he said they work great. 1 Share this post Link to post Share on other sites
Randy_in_Ohio 99 #5 Posted May 7, 2019 Thanks for the warm welcome! Where can I get a hitch receiver like the one in the pic above? Share this post Link to post Share on other sites
ronwh 195 #6 Posted May 7, 2019 Welcome to RedSquare Randy, you can find a hitch like that at www.wheelhorsepartsandmore.com. Thanks Ron Share this post Link to post Share on other sites
Lee1977 7,764 #7 Posted May 7, 2019 Check out Greater Clevenland Tire "Kenda Terra Trac K502 23x10.50x12 4 ply $155 for two." my computer won't let me post a link. Share this post Link to post Share on other sites
RIRed 0 #8 Posted June 25, 2019 Check out "312 walk around" on You Tube. Norman from "I Save Tractors" addresses that issue very nicely. Share this post Link to post Share on other sites
71_Bronco 1,072 #9 Posted June 26, 2019 (edited) I have a set of the Kenda Terra Trac tires, which are the same tread as you posted. Mine are on a Commando 8 that I am currently using just for mowing duty / lawn clean up. I haven't needed to drive the tractor in wet, muddy conditions yet, but I've heard good things about them. I went with these tires as I wanted something a little more aggressive than turfs, for if I need to plow or do wet muddy work. Edit: Pic added. Had just finished mowing when I took it so excuse the dirt / grass clippings Edited June 26, 2019 by 71_Bronco Share this post Link to post Share on other sites
Firebug 267 #10 Posted June 26, 2019 I have about an acre of low swampy grass to mow out back. I switched everything over to ags had a lot of issues with the turf tires just spinning. Haven’t had any issues since. I did learn the hard way that ags aren’t for Ohio winters so I jest one set of turfs with chains for plowing Share this post Link to post Share on other sites
