ET160 30 #1 Posted May 6, 2019 The needle bearings in my B80 PTO clutch were noisy, so I packed the assembly with grease. Now it doesn't disengage fully, so I assume there is too much friction. I think I'm going to tear it all down to inspect. What should I relube with, gear oil? Share this post Link to post Share on other sites
rmaynard 16,895 #2 Posted May 6, 2019 Bearing should be cleaned, then repacked with no more than about a tablespoon of grease. Too much grease will come out on the clutch face and cause slipping. 1 2 Share this post Link to post Share on other sites
rmaynard 16,895 #3 Posted May 6, 2019 (edited) Also, any good wheel bearing grease will be fine. Edited May 6, 2019 by rmaynard Spelling Share this post Link to post Share on other sites
WHX?? 55,219 #4 Posted May 6, 2019 I would also check the seal and replace if worn. 1 Share this post Link to post Share on other sites
ET160 30 #5 Posted May 6, 2019 I checked again and found the outer bearing to be bad. I ordered a new one. Share this post Link to post Share on other sites
