Astrolite 1 #1 Posted April 3, 2009 I picked up an older 42" SD mower deck (late 60s?) and modified it to fit my "75" C-100 by adding the more modern deck mounting hardware. The deck fits the tractor very nicely but now I'm not sure what mower deck drive belt to use. I have several old Gates A105 belts that I thought sure were for this tractor but they are too long. Should a standard drive belt work for this combination or did I create a monster by mixing these parts? Does anyone know if the Gates A105 belt is a direct replacement for a mower drive belt on a C-100/42" SD? Help! Share this post Link to post Share on other sites
Operator 7 #2 Posted April 3, 2009 What I do is take an old unwanted belt and install that and cut to fit then take that off and bring to the belt store and match up with right length. Works every time. I keep old belts just for that purpose. Hope that helps, Randy Share this post Link to post Share on other sites
KyBlue 655 #3 Posted April 3, 2009 String works good for that too...` Share this post Link to post Share on other sites
Astrolite 1 #4 Posted April 3, 2009 Thanks, two really good ideas! I did find out that the A105 belts I have are 105" (makes sense, I guess ) and the stock Wheel Horse belt is 103". Gives me hope. I'll definitly take a measurement before I order anything though. Thanks again. Share this post Link to post Share on other sites
past7971 0 #5 Posted April 3, 2009 As far as "creating a monster", I would say no. The earlier and later 42" decks look identical except for brackets. If you mounted the tach-a-matic brackets correctly to an earlier deck, other than a possible drive belt pulley diameter difference, I see no reason why the "original" belt would not work. The original belt (102742) has been superceded to 94-2501 and is 1/2"x103". Try your 105" and see what you get. If too loose, then hopefully the 103" will do the trick :omg: Share this post Link to post Share on other sites
Astrolite 1 #6 Posted April 11, 2009 Try your 105" and see what you get. The 105" are definately to long. I took 49r Operator's advise and cut one of the three 105" belts I have, looped it around the pulleys and measured. The stock Wheel Horse 103" should fit just fine. Hopefully I can get some paint on the deck before the belt arrives Wednesday. That grass is starting to grow! Share this post Link to post Share on other sites
