Dozer12 0 #1 Posted April 27, 2019 Hey guys, curious if anybody has experienced a no power to coil situation. If I run a jumper wire from positive side battery to positive side coil it fires right up. It's an On an 220. Thanks in advance. Share this post Link to post Share on other sites
953 nut 66,562 #2 Posted April 28, 2019 There are several components between the battery and ignition coil. Any one of them being open could give the same symptoms. Be sure your PTO lever is all the way back, it could be the culprit. This guide has system by system drawings for all late model applications. Find your year and model and then locate the ignition drawing. Some times just cleaning and tightening connections is all that is needed. 1 Share this post Link to post Share on other sites
squonk 46,841 #3 Posted April 28, 2019 First place I'd look is the 9 pin connector. 1 Share this post Link to post Share on other sites
Shynon 7,595 #4 Posted April 28, 2019 54 minutes ago, squonk said: First place I'd look is the 9 pin connector. Share this post Link to post Share on other sites
rmaynard 17,218 #5 Posted April 28, 2019 What year is your 520 assuming that is what you have? Here is page 443 of the demystification guide showing all of the possible safety switches and stuff involved to the circuit from battery to coil. Share this post Link to post Share on other sites
