Matash 15 #1 Posted April 26, 2019 Is there something that can be done to my 314 h to make it keep its speed after turning. It seems like I have to push my control up to increase the speed I was running. ? Thanks Matt Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,535 #2 Posted April 27, 2019 Suspect your tractor is a 1996 314-H model 73403 with a 69xxxxx serial number. Sounds like the friction adjustment could use an adjustment. Don't know why a turn would affect it unless the transmission to frame bolts are loose. They are horizontal and go through the rear frame plate into the front of the transmission. Click on the pictures. Friction adjustment in this manual Garry Share this post Link to post Share on other sites
Matash 15 #3 Posted April 27, 2019 11 minutes ago, gwest_ca said: Suspect your tractor is a 1996 314-H model 73403 with a 69xxxxx serial number. Sounds like the friction adjustment could use an adjustment. Don't know why a turn would affect it unless the transmission to frame bolts are loose. They are horizontal and go through the rear frame plate into the front of the transmission. Click on the pictures. Friction adjustment in this manual Garry Thanks Garry for the helpful info. Ill give it a try in the morning Thats the only issue Im having.. Share this post Link to post Share on other sites
