Countdown To Christmas!
Matash
314 h slows after sharp turns.
Matash
Is there something that can be done to my 314 h to make it keep its speed after turning.  It seems like I have to push my control up to increase the speed I was running.  ?   Thanks Matt
gwest_ca
Suspect your tractor is a 1996 314-H model 73403 with a 69xxxxx serial number.
Sounds like the friction adjustment could use an adjustment. Don't know why a turn would affect it unless the transmission to frame bolts are loose. They are horizontal and go through the rear frame plate into the front of the transmission.
Click on the pictures.
Friction adjustment in this manual
Garry
Matash
Garry
Thanks Garry for the helpful info. Ill give it a try in the morning  Thats the only issue Im having..
