Bv wheel 18 1 #1 Posted April 25, 2019 What s the number on the oil filter for the 520 hdyo bought a fram a little to long Share this post Link to post Share on other sites
WVHillbilly520H 10,377 #2 Posted April 25, 2019 Here's the O.E. TORO as well Onan part numbers...https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F281888642632... 1 Share this post Link to post Share on other sites
Eric C 109 #3 Posted April 25, 2019 You can get the longer filter in the hole....instead of trying to insert the filter the logical way with the filter opening facing away from you and trying to pivot counter clockwise, hold the filter with the open end toward you and insert it past the hole on the engine. Then pull it toward you and pivot clockwise into the hole. I have done this in a pinch with the fram filter. Do yourself a favor and get a napa 1762 filter for the next oil change. 2 Share this post Link to post Share on other sites
oldlineman 1,596 #4 Posted April 25, 2019 I would not use Fram, used to be good filter not somuch now days Bob 1 Share this post Link to post Share on other sites
Bv wheel 18 1 #5 Posted April 25, 2019 19 hours ago, Eric C said: You can get the longer filter in the hole....instead of trying to insert the filter the logical way with the filter opening facing away from you and trying to pivot counter clockwise, hold the filter with the open end toward you and insert it past the hole on the engine. Then pull it toward you and pivot clockwise into the hole. I have done this in a pinch with the fram filter. Do yourself a favor and get a napa 1762 filter for the next oil change. Hey thanks I will do just that Share this post Link to post Share on other sites
Bv wheel 18 1 #6 Posted April 25, 2019 Hey thanks I will do just that Eric thanks Share this post Link to post Share on other sites
WVHillbilly520H 10,377 #7 Posted April 25, 2019 9 hours ago, oldlineman said: I would not use Fram, used to be good filter not somuch now days Bob Share this post Link to post Share on other sites
