cod 122 #1 Posted April 22, 2019 Happen to pull the covers off of my 418 and found that the drive belt is really messed up. Couple of major cracks and missing a piece or two. Ever since I've owned this tractor the T-handle for the drive belt tensioner has rattled around and I'm not sure why. The pulley bearings don't appear to have any slop in them and I added a .010 shim behind the bearing to keep things snug but the rattle doesn't get better. I held a long straight edge against the tranny pulley and appears to be inline with the PTO pulley so I'm perplexed. I don't see any burrs or nicks in the pulleys and the belt is the correct number (108501) so any pointers would be greatly appreciated. Cod Share this post Link to post Share on other sites
cleat 8,456 #2 Posted April 23, 2019 I have only one 520 early enough to have came with the release. It rattled and vibrated so I just eliminated it like all the later models. Cleat 1 Share this post Link to post Share on other sites
peter lena 9,654 #3 Posted April 23, 2019 those cracks can come from general age and wear, also from not enough tension to prevent the belt from being in a constant buzzy loose state. the noise on the belt tensioner sounds strange , almost like its not mounted right. not likely but a total look at all mounting points can,t hurt. pete 1 Share this post Link to post Share on other sites
cod 122 #4 Posted April 25, 2019 I've got a new one on the way and I think when I install it, I'll try running it without the side cover and see if there is something obvious that stands out. I also think I'll start writing down the date when I replace the belt on the inside of the side cover to get an idea of how the rascal lasts. Cod 1 Share this post Link to post Share on other sites
cod 122 #5 Posted April 29, 2019 New belts came and I ran it for a spell without the side cover and everything looks fine. I rechecked the pulley alignment and oddly enough when I engaged the belt tensioner, the rattle was gone. I suspect that the old belt was so worn that it was causing the rattle and as the new fits like a glove, it's more snug and there is no play to be had. I did mark the date for the new belt as I'm curious to see how long it will last and as there really seems to be a wide variety of standards in the belt industry and it's tough to know in advance if you are really getting a quality item when you're in a rush to get the yard done. Cod Share this post Link to post Share on other sites
