WH656 9 #1 Posted April 22, 2019 I dont have a proper measuring tool and want to be sure I get it right.. Cant tell if its 7/8 or 1" or what.. Thanks in advance! Share this post Link to post Share on other sites
ebinmaine 77,076 #2 Posted April 22, 2019 when you say driveshaft I assume you're talkin about the shaft that goes from inside the transmission out to the wheel hub. That is 1" Share this post Link to post Share on other sites
ebinmaine 77,076 #3 Posted April 22, 2019 I'm curious to know why you need that measurement? Are you looking for seals or something? Share this post Link to post Share on other sites
WH656 9 #4 Posted April 22, 2019 Thanks. Yes. Well the tecky is running erratically and I dont have time to fool with it right now. I am going to rebuild it over the winter and for now put a predator on it to finish out my season. I am going to need an adapter sleeve and trying to figure out what size.. I *think* from what you are saying, that will be: 3/4" to 1" Inch w/Step Key Gas Engine Pulley Crank Shaft Sleeve Adapter Predator.. 2.5" length.. Share this post Link to post Share on other sites
ebinmaine 77,076 #5 Posted April 22, 2019 Okay. I understand. When you say drive shaft what you actually mean is the engine crankshaft. I'm fairly sure that is still 1" but I'm not at all familiar with those Predator engines or how to adapt it into place. Share this post Link to post Share on other sites
WH656 9 #6 Posted April 22, 2019 Yes, sorry I should have said crank shaft. I think the engine will just need a shim under it or sorts.. like 1/4" and then the crank adapter and should line up fine. Share this post Link to post Share on other sites
ebinmaine 77,076 #7 Posted April 22, 2019 Other people have done this swap of course. You could search around on the site and get a fair amount of information. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,981 #8 Posted April 22, 2019 Do you have 3/4", 7/8" and 1" open ended wrenches? They make a poor man's caliper for such measurements. Garry 4 Share this post Link to post Share on other sites
Achto 30,847 #9 Posted April 22, 2019 Purchasing a pulley with the correct ID for the Predator engine may be cheaper than an adaptor. 1 Share this post Link to post Share on other sites
