buffaloman 295 #1 Posted April 21, 2019 So all of a sudden my C-120 will start to lose power ,backfires a few times, and shuts off. I can start it right back up and it will do the same thing all over again.I replaces the condenser, the coil ,the ground wire and checked the points and reset them. any other ideas? Thanks Share this post Link to post Share on other sites
Hacksawhero123 351 #2 Posted April 21, 2019 My ammeter shorted out and was doing something similar to that. Mark Share this post Link to post Share on other sites
buffaloman 295 #3 Posted April 21, 2019 5 minutes ago, Hacksawhero123 said: My ammeter shorted out and was doing something similar to that. Mark never even thought of that .thanks ill be checking that out. Share this post Link to post Share on other sites
Tractorhead 9,216 #4 Posted April 21, 2019 Is compression right ? Think this can be faulty valvesettings, maybe didn‘t close tightly. Share this post Link to post Share on other sites
wallfish 19,322 #5 Posted April 21, 2019 In addition to above Flooding of fuel will also cause that condition. An intermittent electrical problem? with a safety switch? ground? More details might help with internet diagnosis. Does it run for 2 hours then this begins or right away or 5 minutes. Sometimes? all the time? this condition started to happen suddenly? or slowly progressed over time? Or after some service work was done on it? Happens while sitting still? or mowing the grass? Only when PTO is engaged? Original Kohler engine? replacement engine? 1 Share this post Link to post Share on other sites
Hacksawhero123 351 #6 Posted April 21, 2019 The power for the ignition is seriesed through the ammeter. Mine was rotten inside (43 years old, go figure) and vibration was causing the somewhat intermittent failure. I happened to see some sparks in it in the low lighting. For now, it’s just bypassed. Best of luck to you. Mark Share this post Link to post Share on other sites
Hacksawhero123 351 #7 Posted April 21, 2019 Question..... Does it try to run as long as you’re on the starter, but dies as soon as you let go of the switch? Share this post Link to post Share on other sites
lynnmor 8,628 #8 Posted April 21, 2019 Loosen the gas cap and try again. Share this post Link to post Share on other sites
Tractorhead 9,216 #9 Posted April 21, 2019 Maybe simpler issues? When did you last time checked the Air filter? Fuelfilter ( if there is one in) ? maybe some rust in the Fueltank? Share this post Link to post Share on other sites
RetroMower 350 #10 Posted April 22, 2019 11 hours ago, Hacksawhero123 said: Question..... Does it try to run as long as you’re on the starter, but dies as soon as you let go of the switch? My c100 does this and backfires if it starts. How difficult is it to bypass the ammeter as you have done? Share this post Link to post Share on other sites
Hacksawhero123 351 #11 Posted April 22, 2019 Just bypass it. Splice the two wires together and insulate them. Mark. 1 Share this post Link to post Share on other sites
