can whlvr 994 #1 Posted April 2, 2009 Here are some pics of the 300 with the new duals on it,it sure pulls with authority now but i saw the post from dualwheels about the broken axle when running dual wheels with a fel and am a little nervous myself because i use her pretty hard!!! Share this post Link to post Share on other sites
Buzz 502 #2 Posted April 2, 2009 Looks good Why don't you try Nicks trick and reduce the air pressure in both outer tires? Share this post Link to post Share on other sites
kpinnc 17,143 #3 Posted April 2, 2009 i saw the post from dualwheels about the broken axle when running dual wheels with a fel and am a little nervous myself because i use her pretty hard!!! I would be further concerned since the 308 has 1 inch axles. The 520 used 1 and 1/8th axles, and still broke one. Kevin Share this post Link to post Share on other sites
WHC-125 4 #4 Posted April 2, 2009 I gave wheelhorse101(Dan) a set of wheels and he now has dual wheels on his C-81 and I will cross my fingers that his doesnt break. :omg: Share this post Link to post Share on other sites
Docwheelhorse 2,874 #5 Posted April 2, 2009 He won't have an issue.... ---unless--- he adds a weight bucket and over 300 lbs in it to the rear axle. Thats what killed the 520.... Tony Share this post Link to post Share on other sites
can whlvr 994 #6 Posted April 2, 2009 Thanks for the input guys im going to reduce the air presure thought about putting the duals on the 414-8 with the bigger axles and the 8 pinion but it is set up better for lawn duty because it has lights and the 300 is really more for beating up anyway :omg: Share this post Link to post Share on other sites
