Larry Chamberlain 29 #1 Posted April 19, 2019 Are the loops all interchangeable on the wheel horses I'm trying to use the one off of my old 8hp on 12hp Share this post Link to post Share on other sites
troutbum70 858 #2 Posted April 20, 2019 I would think if it fits and everything lines up it should work. 1 Share this post Link to post Share on other sites
pfrederi 20,871 #3 Posted April 20, 2019 (edited) There are at least two different size PTO loops. But like Trout said if it lines up use it. Edited April 20, 2019 by pfrederi 2 Share this post Link to post Share on other sites
peter lena 9,945 #4 Posted April 20, 2019 remember that the top angular engagement plate ,can also be used UNDER the engine mount for a clearance/ fit issue. just put the upper bronze bushing , under the plate on the bottom. letting you still use the lever rod engagement point, but at a different level, pete 2 Share this post Link to post Share on other sites
