WHwest8597 85 #1 Posted April 18, 2019 Any suggestions for adding at fuel filter to models that did not come with filters originally. My 50th Anniversary 314-8 did not come with a fuel filter. What filter should I use? Share this post Link to post Share on other sites
The Tuul Crib 7,353 #2 Posted April 18, 2019 20 minutes ago, WHwest8597 said: Any suggestions for adding at fuel filter to models that did not come with filters originally. My 50th Anniversary 314-8 did not come with a fuel filter. What filter should I use? Any small inline filter should work. Share this post Link to post Share on other sites
RetroMower 350 #3 Posted April 18, 2019 1 hour ago, WHwest8597 said: Any suggestions for adding at fuel filter to models that did not come with filters originally. My 50th Anniversary 314-8 did not come with a fuel filter. What filter should I use? Any small inline fuel filter thats double barbed or flared to fit inside rubber fuel lines will work. Some like the clear filters which act as a visual aid for fuel flow or even the small briggs and Stratton plastic discs that are basically just an inline screen to capture particles will work. They are WH red to boot 1 Share this post Link to post Share on other sites
squonk 46,023 #6 Posted April 19, 2019 Those clear plastic filters work well but I have had more than one that became air locked when first filling with fuel or when you run out of gas. Take the outlet hose off and get fuel flowing and all is good. 1 Share this post Link to post Share on other sites
formariz 12,359 #7 Posted April 19, 2019 I now always use two of them. I remove the screen from inside tank since eventually always gets clogged and it is a pain to clean tank. I place the first one right out side tank. That one gets changed frequently since it always show crud in it. Share this post Link to post Share on other sites
ashtonosborne2019 18 #8 Posted March 21, 2021 On 4/18/2019 at 5:36 PM, WHwest8597 said: Any suggestions for adding at fuel filter to models that did not come with filters originally. My 50th Anniversary 314-8 did not come with a fuel filter. What filter should I use? if you go on amazon and search fuel filters there should be a 12 or 14 pack of filters that fit in all of my machines. Share this post Link to post Share on other sites
