richmondred01 2,307 #26 Posted April 18, 2019 Just now, WVHillbilly520H said: 10 gallons for the year? Are you sure especially if you mow once a week till fall. Must be a k181. Share this post Link to post Share on other sites
Cadmandu 67 #27 Posted April 18, 2019 I put slow grow on my yard in the spring. Only need to mow about eight times Share this post Link to post Share on other sites
JAinVA 4,638 #28 Posted April 18, 2019 (edited) I can go through 10 gallons a month and have done so many times.If you use these machines as most here, you have way more than one and spares for expendables is part of the hobby.In my case I hate to describe my use of the Horse as a hobby.I work mine hard and often. Edited April 18, 2019 by JAinVA Share this post Link to post Share on other sites
Cadmandu 67 #29 Posted April 18, 2019 I spend 12 hrs a year riding it and 24 hrs working on it. I would like to buy a C-160 1 Share this post Link to post Share on other sites
Daddy Don 909 #30 Posted April 18, 2019 I did away with the screen in the tank and put a good inline fuel filter on my . Now I can see if the fuel is flowing ok form the tank. And a lot easier to change. Share this post Link to post Share on other sites
ebinmaine 73,037 #31 Posted April 18, 2019 4 hours ago, Daddy Don said: see if the fuel is flowing ok To that end I also have changed ALL our tractors and other small engine machines to see through line. Bought a roll from @A-Z Tractor Lincoln. Makes diagnosis easier and can see foreign matter in the system. Share this post Link to post Share on other sites
ebinmaine 73,037 #32 Posted April 18, 2019 6 hours ago, Cadmandu said: I spend 12 hrs a year riding it and 24 hrs working on it. We'll try to reduce that ratio a bit. C160.... Yeah. Share this post Link to post Share on other sites
Cadmandu 67 #33 Posted April 18, 2019 Most of my work is just upgrading stuff. New tires front and rear new and bigger rims and steering spindles 1 Share this post Link to post Share on other sites
Cadmandu 67 #34 Posted April 18, 2019 If I give some money to the forum can I send pics Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #35 Posted April 19, 2019 3 hours ago, Cadmandu said: If I give some money to the forum can I send pics You can post pics, up to a certain amount of MB but yes if you become a supporting member, you'll have unlimited uploading... Share this post Link to post Share on other sites
Cadmandu 67 #36 Posted April 23, 2019 Hi all i got my shutoff and grommet yesterday. When I remove and install is this the correct method? 1) pull the valve first then pry out grommet 2) then install new grommet first then push in valve. or install and remove as an assembly thanks Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #37 Posted April 23, 2019 (edited) 54 minutes ago, Cadmandu said: When I remove and install is this the correct method? 1) pull the valve first then pry out grommet 2) then install new grommet first then push in valve. thanks and use a bit of motor oil to lube up that grommet first. Edited April 23, 2019 by WVHillbilly520H Share this post Link to post Share on other sites
Cadmandu 67 #38 Posted April 23, 2019 Okay thanks, so do not install as an assembly correct? Oil is a good idea. Share this post Link to post Share on other sites
ericj 1,579 #39 Posted April 24, 2019 I do not like to put oil on rubber fittings, I've used a little squirt of carb and choke cleaner. Anything wet will help it slid together easier. eric j Share this post Link to post Share on other sites
Cadmandu 67 #40 Posted April 24, 2019 How about vasaline Share this post Link to post Share on other sites
richmondred01 2,307 #41 Posted April 24, 2019 Spray silicon works well Share this post Link to post Share on other sites
Cadmandu 67 #42 Posted April 24, 2019 Okay I have some for motorcycle chain lube Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #43 Posted April 24, 2019 38 minutes ago, Cadmandu said: How about vasaline That works too, and just a small bit of oil wont hurt even WD40 just something to lube it before installing. Share this post Link to post Share on other sites
